I made two surfaces, generated by the following code. I want to extract the edges of these two surfaces and use the lofting command to generate a cylinder. What should I do?
points = [Vector(0,0,0), ......]
surface = Part.BSplineSurface()
surface.approximate(points)
surface.setVPeriodic()
obj.Shape = surface.toShape()
