In Sheet Metal workbench I'm trying to create this sharp dimple using the Forming in Wall tool:
I tried using a cylinder to perform this, but can't rotate the dimple afterwards for it to look as desired.
I also tried creating a face in the cylinder and use it, but I get an invalid shape:
Is it possible to perform this with Sheet Metal?
With Forming in Wall tool it seems that it only accepts a face of the forming tool, then it places the face perpendicular to the sheet metal face and performs the operation.Create sharp dimple with Sheet Metal Forming in Wall?
- papyblaise
Re: Create sharp dimple with Sheet Metal Forming in Wall?
it's wrong with Sheetmetal, it'll edge you with an R= to the thickness
you have to make a Pad with a sketch at 30°, a Pocket with another, then surface what is left
- dimple.FCStd
- (26.48 KiB) Downloaded 6 times
- dimple.JPG (14.79 KiB) Viewed 306 times
