(WORKAROUND) Help interpreting an error message
thomas-neemann
Post by thomas-neemann »
What could this error message mean?
Is the model still usable?
07:00:55  <Part> ViewProviderExt.cpp(1266): Cannot compute Inventor representation for the shape of rep20_24he_waermetauscher_8jun658#Compound036011: Bnd_Box is void
Version: 0.21.0.33345 (Git) AppImage
Hash: a3c4f4bb01f5201daf666852444a8f9c5adbda8d
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Last edited by thomas-neemann on Thu Jun 08, 2023 5:29 am, edited 1 time in total.
thomas-neemann
Re: Help interpreting an error message
workaround
If I select everything via box selection and create a simple copy and only continue to work with the copies, the error message is gone
Re: (WORKAROUND) Help interpreting an error message
thomas-neemann wrote: Thu Jun 08, 2023 5:04 am Is the model still usable?
Very hard to tell a) without the model and b) without knowing what you intend to do with it.
thomas-neemann
chrisb wrote: Thu Jun 08, 2023 5:50 am
I got the model from another freecd user to expand it. under time pressure i added freecad geometry, a mesh and some step files. During this time, error messages appeared, but I couldn't take care of them due to time constraints. now I would like to eliminate the error messages afterwards and for the future I only need the geometry without parametric but with color information. I succeeded with the workaround.
Roy_043
Post by Roy_043 »
The error message points to an object that has an empty shape.
thomas-neemann
Roy_043 wrote: Thu Jun 08, 2023 7:40 am The error message points to an object that has an empty shape.
Thanks for the info. through which workflow can something like this arise, for example?
thomas-neemann wrote: Thu Jun 08, 2023 7:42 am through which workflow can something like this arise, for example?
Didn't it happen with your workflow? I don't understand why you are not providing the file and give a detailed description of what you have done if you want more information. Meshes are always candidates for having an emnpty shape.
Roy_043
Post by Roy_043 »
For example a Part_Common will produce this error if the original objects no longer overlap.
thomas-neemann
chrisb wrote: Thu Jun 08, 2023 7:50 am
that won't be of much use because i took over the file and don't know how it came about. I also have no influence on the step files and the mesh. It helps me if I know that e.g. step files can cause such problems.
thomas-neemann
Roy_043 wrote: Thu Jun 08, 2023 7:52 am For example a Part_Common will produce this error if the original objects no longer overlap.
thanks this is helpful for me
