Possible Bug in Current Development Version: Selecting Vertex in Detail View
in the current development version it's not possible to select a vertex point inside the circle of the original view.
It's working in the current stable 20.2, see screenshot
Using:
OS: macOS 13.4
Version: 0.21.0.33357 (Git)
Hash: f0560ac2078ad71b4c97b74281990bb916431da9
Python 3.11.3, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.2, OCC 7.7.1
Locale: C/Default (C)
* fasteners 0.4.56
* sheetmetal 0.2.63
Using:
OS: macOS 13.4
* fasteners 0.4.56
* sheetmetal 0.2.63
Re: Possible Bug in Current Development Version: Selecting Vertex in Detail View
I cannot replicate the issue using:
Version: 0.21.0.33366 (Git)
Hash: d8150a9cd97bb94712feb6699f32aacc28b2910c
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
* Silk 0.1.3
* A2plus
* Defeaturing 1.2.0
* CurvedShapes 1.0.4
* MakerWorkbench 1.0.1
* freecad.gears 1.0.0
* Curves 0.6.8
* toSketch 1.0.1
* Plot 2022.4.17
* AirPlaneDesign 0.4.0
* fasteners 0.4.56
* sheetmetal 0.2.63
Version: 0.21.0.33345 (Git) AppImage
Hash: a3c4f4bb01f5201daf666852444a8f9c5adbda8d
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
* Silk 0.1.3
* A2plus
* Defeaturing 1.2.0
* Curves 0.6.8
* toSketch 1.0.1
* Plot 2022.4.17
* fasteners 0.4.56
* sheetmetal 0.2.63
- wandererfan
Hi @pboe, hello to the Community!
I too can't replicate the error you reported, could you attach the file?
I think I've worked out what the OP is trying to state. When a Detail View is created, all the marks/vertices in the dotted circle generated on creating the Detail View are nolonger selectable. Works fine in 0.20.x master. Looks like it's been like this since at least 30th Jan 2023.
Version: 0.21.0.33377 (Git)
Hash: ef07c3005ed44e79e4b5272c2cb4fcfed69f2a54
* Silk 0.1.3
* A2plus
* Defeaturing 1.2.0
* Curves 0.6.8
* toSketch 1.0.1
* Plot 2022.4.17
* fasteners 0.4.56
* sheetmetal 0.2.63
Sorry for the late reply. That's exactly the behavior I have on MacOS.Syres wrote: ↑Wed Jun 07, 2023 6:28 pm I think I've worked out what the OP is trying to state. When a Detail View is created, all the marks/vertices in the dotted circle generated on creating the Detail View are nolonger selectable. Works fine in 0.20.x master. Looks like it's been like this since at least 30th Jan 2023.
- wandererfan
The detail highlight on the base view is stacked above the vertices so you can grab it and drag to a new anchor point. This blocks the selection of the vertex behind the highlight. Simple solution is to change the stacking level of the highlight, but I'm still checking if this messes up something else.
- wandererfan
Thank You very much Wandererfan for your lighspeed debugging
