How to fillet mirrored part
Re: How to fillet mirrored part
Thanks. 'Validate sketch" and then the check for missing coincidences seems to be how you verify that the shape is closed.
Why must all neighboring arcs be tangent, instead of merely having their endpoints be coincident? And what does one do where an arc meets a straight line at a sharp angle (as two do on the flat side of this sketch)?
Here's tangency vs. coincidence: https://www.youtube.com/watch?v=cUV_QZuNFHI
That's good after the fact. I tend to check before applying dimensional constraints. That's why I mentioned the "wiggle" method, with it you don't need to close the sketch...that and makes it easy to find non-coincident vertexes.MobiusStrip wrote: ↑Wed Jun 07, 2023 6:43 pm Thanks. 'Validate sketch" and then the check for missing coincidences seems to be how you verify that the shape is closed.
Because, the fillet routine follows edges. It decides whether to continue onto the next segment by whether it is tangent or not. So, if you want it to automagically follow what you see as a continuous edge, then you must make it tangent.Why must all neighboring arcs be tangent, instead of merely having their endpoints be coincident? And what does one do where an arc meets a straight line at a sharp angle (as two do on the flat side of this sketch)?
As for your video. Box select the vertexes, not the lines.
But the fillet can follow right-angle corners, and they're not tangent.
Right, but the fillet routines just don't like "kinda tangent". It's just the way they are.MobiusStrip wrote: ↑Wed Jun 07, 2023 7:20 pm But the fillet can follow right-angle corners, and they're not tangent.
But you need to select each side for the fillet.MobiusStrip wrote: ↑Wed Jun 07, 2023 7:20 pm But the fillet can follow right-angle corners, and they're not tangent.
We don't know in your model if you want a smooth continuation between lines or not.
That was recently fixed in the Master version. Will be included in the upcoming release of 0.21.MobiusStrip wrote: ↑Wed Jun 07, 2023 6:16 pm The message in the report window to check the report window is obviously useless.
Gene
Hm, I don't know what this means. But I tried just making an arbitrary shape with sharp angles, some adjoining arcs, and not a tangent in the entire sketch. And it fillets without complaint.
- ring.FCStd
- (378.16 KiB) Downloaded 12 times
Please : new file -> new name.
You can fillet edges when there is no tangency (=hard corner) but you need to select each edge 'around' this corner.
When there is tangency, you select one edge and fillet will be propagated along all tangent edges.
Here, filleting the face will fillet all edges from this face. But in the 1st file, you will need to select each 'part' of the border (and not the face because one edge will be needed for the mirror). Usually, for 'smooth' corner, you want tangency. I don't know what is needed in your 1st file (as it is not fully constrained).
Thanks again for taking that time.
The new shape has no constraints either, though (except the auto-generated coincidence and a vertical one).
Regardless, it looks like there are some bugs at play here. Following your note about selecting individual faces, I tried that on the problematic piece; I selected the pad element in the model treeview, and then all the faces except the flat one along which I'll mirror, and pressed the fillet button. It worked.
I undid that and went back and just selected the pad and pressed the fillet button. Now it works without complaint. Just to be sure this was a change in the software's state and not the file, I reloaded the one I posted here and tried it. Same result: Now the fillet works on the pad.
However, selecting the faces causes both the top and bottom to be filleted. So I tried just selecting the curved edges on the top side. Filleting still fails with a recomputation error. And the edge-selection control in the fillet panel definitely does not seem to work right: https://youtu.be/J_S8jp4nhoM
And I still can't get filleting to work after the part is mirrored. If I fillet it as depicted in the screen shot above and then mirror it, of course I get the indentations in the edge along the plane of reflection.
