Hello everyone,
I have an assembly created with assembly 3 containing two parts (fixed together using point-plane distance constant). I would like to automatically edit certain dimensions of the individuals parts based on a a tolerance range and then recompile the assembly. I plan to do this multiple times (>1000) for tolerance analysis studies so would like to automate this. Eventually I would like to all for individual assembly parts outputted as .stp files for some post processing.
Is there a way to do this in python i.e change certain dimensions of the bodies and recompute the assembly while keeping the tolerances the same ? I attempted this with the attached code.
Any other pointers on how to achieve the goal would be much appreciated!
Thanks!
Editing parts in Assembly 3 from Python Script
- test3.py
- Python file
- (1.35 KiB) Downloaded 24 times
- Code screenshot
- assy3 screenshot.jpg (188.17 KiB) Viewed 1756 times
