Artifact in a drawing
ebolisa
Post by ebolisa »
I designed a simple horn using additive loft, looks ok and error free in FC but when I export it to prusaslicer, I get a hole where it curves
What's causing it?
TIA
Locale: Spanish/Spain (es_ES)
  * Assembly4 0.12.6
  * Curves 0.6.8
  * dodo 1.0.0
  * fasteners 0.4.55
  * Lithophane
  * sheetmetal 0.2.63
  * ThreadProfile 1.84.0
test.FCStd
(142.51 KiB) Downloaded 14 times
Roy_043
Re: Artifact in a drawing
Post by Roy_043 »
The wall thickness in that area is less than zero. If you change the Lighting of the Body to "One side" and change its Transparency to zero you will see the same artifact in FreeCAD.
ebolisa
Post by ebolisa »
Roy_043 wrote: Sun Jun 04, 2023 5:59 pm The wall thickness in that area is less than zero. If you change the Lighting of the Body to "One side" and change its Transparency to zero you will see the same artifact in FreeCAD.
Thanks, I kind see that now but where's the option of "Lighting" at?
Roy_043
Post by Roy_043 »
Select the Body and go to the View tab in the Combo view.
