I'm using v0.20 right now and the model I'm currently working on has become very slow, to the point where it's almost unworkable (have to wait several seconds after just about every click). I'm fairly new to FreeCAD so I'm wondering if it has something to do with how I structured my model. I'm trying to do everything parametrically, so I have a ton of different parameters with varying relationships between them - could this be what's slowing it down? What could I do to avoid this problem in the future?
Model here: https://www.dropbox.com/s/fkewr2bnh4cqs ... FCStd?dl=0
Very slow model
Re: Very slow model
Hi and welcome to the forum!
You uploaded a backup file. Is this intended or did you rather wanted to upload the latest FreeCAD file?
- thomas-neemann
Re: Very slow model
does it get faster if you don't use aliases, but directly the cell names? e.g. B3
Re: Very slow model
You should be more specific here. I loaded your model, which expectedly took quite some time, but then I could well click through the tree and show the different states of your model.namelessguy0 wrote: ↑Sun Jun 04, 2023 1:42 am (have to wait several seconds after just about every click)
I edited the last sketch, removed one of the dimensions and replaced it with an equality without any time lag at all.
So here are my two guesses:
- you edit the Spreadsheet and it takes very long. This is expected, because all objects depending on some even not edited value of it are recomputed. That can not really be avoided, but can be improved by creating multiple spreadsheets
- You have "Auto update" enabled in Sketcher.
That causes a recompute on every change in the sketch and you should switch it off. Then the recompute occurs only on closing the sketch.
See the page about the topological naming problem about the issue and have a look at this page, especially the paragraph about creating stable models
Re: Very slow model
I understand making parts parametric via spreadsheet but is this level of changeability needed i.e. for the design? If you are making everything parametric then maybe assembly would be a better approach.I'm fairly new to FreeCAD so I'm wondering if it has something to do with how I structured my model. I'm trying to do everything parametric
Re: Very slow model
I do not think, that the spreadsheet is here to blame, since it is one Body. I think the missing of refinement option with the combinations with fillets any many many coplanar arrays makes the kernel slow. Also is is build up very fragile. I tired it refine it and it breaks immediately.
Greetings
user1234
Greetings
user1234
Re: Very slow model
I became aware of that issue after I first created this model and will definitely take that into account going forward. Thanks for the help, I'll try using multiple spreadsheets and turning off automatic recompute for sketches.chrisb wrote: ↑Sun Jun 04, 2023 5:39 amBut there is something far more serious in your model: You attached your DatumPlanes to generated geometry. I don't know if this slows down the recompute time, but you should avoid this completely, because it makes your model extremely fragile.namelessguy0 wrote: ↑Sun Jun 04, 2023 1:42 am (have to wait several seconds after just about every click)
