Making ellipse or rectangle always half as wide as its width
Frotz
Post by Frotz »
How is the formula editor for constraints supposed to work? I have an ellipse that I want to ensure is always half as wide as its length (or do some arithmetical transform to set Width as N x Height). Where is it documented how to make sense of the <<ThingName>> stuff that pops up in the formula editor when you click on the formula icon when editing a constraint? I figured it would be something like <<ThingName>>.Length (this grammar doesn't work) to stand in for a particular value on some other constraint.
OS: Debian GNU/Linux 12 (bookworm) (MATE/mate)
Version: 0.21.0.33341 (Git)
Hash: 8a3c8258dfe92bdfe5efcfea43b0c1e2a224543c
Python 3.11.2, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Pyramids-and-Polyhedrons
  * sheetmetal 0.2.63
  * freecad.gears 1.0.0
  * A2plus 0.4.60k
  * fasteners 0.4.56
  * Manipulator 1.5.0
edwilliams16
Re: Making ellipse or rectangle always half as wide as its width
Post by edwilliams16 »
Expressions
The downside of trying to use self referential expression within a sketch is that it is outside the sketcher solver. It might not ever converge.
Absent a ratio feature, you can construct any desired ratio with a right angle construction triangle. Set your desired lengths equal to two sides of the triangle. Make the lengths of the two sides in the desired ratio - but as reference lengths. Set the angle of the triangle as a driving constraint, fixing its geometry.
Screenshot 2023-06-03 at 1.59.04 PM.png (41.18 KiB) Viewed 840 times
viewtopic.php?t=69147
EDIT Rectangles are much simpler.
Screenshot 2023-06-03 at 3.00.19 PM.png (20.96 KiB) Viewed 809 times
twotooneellipse.FCStd
(4.14 KiB) Downloaded 10 times
If it is really and always double you don't need any dimensions. Use three lines of equal length, one vertical, two horizontal:
Workshop_Notes
Post by Workshop_Notes »
chrisb wrote: Sun Jun 04, 2023 5:16 am If it is really and always double you don't need any dimensions.
Clever and understated.
That method has much wider applicability in that it can be used for _any_ rational (able to be expressed as a fraction) number.
Even for irrational numbers, continued fractions can be used to obtain a rational number arbitrarily close to the correct one (e.g pi can can be 355/113). [side note, what is the angle of Ed's right angle triangle for pi ratio sides?]
It would become slightly tedious when the numerator and denominator of the rational number sum to more than about 7 though. I wonder if Lattice 2 might be a good way of producing the ratio (make a 355 x 113 array).
edwilliams16
Workshop_Notes wrote: Sun Jun 04, 2023 8:03 am
Tedious yes - when all you need to do is make a triangle with one side 1 and the other pi and make the angle a driving constraint - plus it's good to machine accuracy.
The angle is atan (pi) (or atan(1/pi) ) depending which side is which. But you don't need trig - the correct angle is constructed.
