Cannot mirror additive Loft/Pipe
last_not_used_login
Post by last_not_used_login »
I'm finishing my zip-cover for my backpack and I would like to do a mirror of additive loft/pipe, but after mirror nothing happen or I get error.
Could you advice? What I'm doing wrong?
file attached.
Thanks!
Locale: Polish/Poland (pl_PL)
  * A2plus 0.4.60k
  * Assembly4 0.12.6
  * Curves 0.6.8
  * ExplodedAssembly
  * fasteners 0.4.55
  * freecad.gears 1.0.0
  * lattice2 1.0.0
  * Manipulator 1.5.0
  * ThreadProfile 1.84.0
Screenshot 2023-05-30 202032.png (59.53 KiB) Viewed 1293 times
bagpack-zipper-handler.FCStd
(207.47 KiB) Downloaded 20 times
last_not_used_login
Re: Cannot mirror additive Loft/Pipe
When I added pocket, now I'm able to create mirror.
papyblaise
Post by papyblaise »
AddPipe or Loft generates B-splines that Fc handles poorly
for it to work, the contact must be unambiguous, you add in Y +1.01mm and it works
handle.FCStd
(242.72 KiB) Downloaded 9 times
Shalmeneser
Post by Shalmeneser »
Sketch007 (Top001) has a weird (and bad ?) attachment.
I think it's not fully vertical so th mirror has problem.
The arc from the Profile sketch can be used for the attachment.
bagpack-zipper-handler_SHALM.FCStd
(200.1 KiB) Downloaded 10 times
user1234
Post by user1234 »
When as mirror plane the object face is selected, it works without issues.
The reason might be, that the plane is not perfect on the origin plane. The attachment calculator of the placement is not precise enough. I saw that more recently.
Placemetn should be 240deg, and 3 times |0.5773502691896258|.
There is already a ticket for that.
Greetings
user1234
last_not_used_login
papyblaise wrote: Sun Jun 04, 2023 11:01 am AddPipe or Loft generates B-splines that Fc handles poorly
Thanks!
Could you explain? I don't see any different in you file. What have you changed/ where have you add 1.01 mm?
papyblaise
Sorry my mistake
Y= +0.01mm (10Mu M)
Attachement >Position > Y
domad
Post by domad »
last_not_used_login wrote: Sun Jun 04, 2023 3:51 pm ...
Hello last_not_used_login, greetings to the Community!
Your "zip" with the mirroring on the plane you had chosen (not perfectly orthogonal), to do this just place a "datum-plane" correctly.
In the animated gif you can see the dynamic behavior in real time as the parameters vary (which can be increased by creating new ones), obviously it is only an example obtained using the "DynamicData" Wb, but the same result can be obtained with the spreadsheet Wb .
Dynamic-bagpack-zipper-handler_domad.FCStd
(244.3 KiB) Downloaded 10 times
