Additive pipe vs additive loft
last_not_used_login
Post by last_not_used_login »
I need to create a part which has a profile and multiply cross-section (rectangle, circle and slot) - my part has to have inner section (circle).
I know that I have to use additive pipe/loft, but I don't understand different between them.
My understanding is that additive pipe is the same as the loft(with the same features, including creating inner section) with extra possibility to sweep along profile.
Other words I can achieve exactly the same using loft and pipe.
Could you correct me if I'm wrong?
If the question is stupid- sorry, I'm still learning. I haven't found answer for this question in docs and on multiply tutorials as well.
Thanks!
Locale: Polish/Poland (pl_PL)
  * A2plus 0.4.60k
  * Assembly4 0.12.6
  * Curves 0.6.8
  * ExplodedAssembly
  * fasteners 0.4.55
  * freecad.gears 1.0.0
  * lattice2 1.0.0
  * Manipulator 1.5.0
  * ThreadProfile 1.84.0
NewJoker
Re: Additive pipe vs additive loft
Post by NewJoker »
PartDesign AdditivePipe = sweeping a profile along a path (with an option for additional profiles)
PartDesign AdditiveLoft = connecting multiple profiles (cross-sections) with no option for guide curves (unfortunately)
jfc4120
Post by jfc4120 »
A loft is different from a sweep. A sweep will calculate miters. A loft follows, no miters. Additive pipe can work more like part sweep if needed.
Edit:
Image is a double offset (a change in two directions) Also a change in size. Additive loft will not do this, additive pipe will. You have to do a little calculating however first with a change in size.
