BIM Project Set-up - Floor Object and Working Plane Proxy - Z-axis
arxerxes
Post by arxerxes »
When using BIM Project Set-up, the floor object and work plane proxy seem to have different different Z-axis values when they are expected to be the same. Screenshot attached. FreeCAD version details below:
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
  * BIM 2021.12.0
  * CADExchanger
  * Curves 0.6.9
  * fasteners 0.4.56
BIM Project Set-up Level WPP Level.jpg (592.36 KiB) Viewed 1604 times
Roy_043
Re: BIM Project Set-up - Floor Object and Working Plane Proxy - Z-axis
Post by Roy_043 »
This is intended behavior. The idea is that the base geometry for each floor is created on a different plane.
arxerxes
Post by arxerxes »
I am not sure I follow. Why would a level-0 objects such as walls be created on a plane with z-axis coordinate of level-1?
arxerxes
Post by arxerxes »
Thank you
