Problem converting STL to Freecad solid
I downloaded a design from Thingiverse which I would like to modify.
There are 5 STl files, 4 of which convert with no problems
One, which is the most complicated part, does not convert.
I follow the instructions in the Freecad wiki:
open stl
analyze and repair (this one had a problem with intersections which was repaired)
harmonize normals
fill holes
convert mesh to shape
make a copy - refine shape (this stage takes a long time on my PC - several minutes)
convert to solid
It is at the last stage that Freecad fails with an error message:
11:48:04 Traceback (most recent call last):
File "<string>", line 2, in <module>
<class 'Part.OCCError'>: Creation of solid failed:
11:48:04 Cannot convert Part_Cooling_Duct001001 because Creation of solid failed: .
Any idea?
Cannot upload problematic STL since it is too large.
This is a link to it in Thingiverse, and the problematic file is "part_cooling_duct"
https://www.thingiverse.com/thing:4002782
open stl
harmonize normals
fill holes
convert to solid
Any idea?
Re: Problem converting STL to Freecad solid
I didn't look at the file, but you may have multiple components in the mesh. Try "Split by components" before converting to shape and solid.
- thomas-neemann
here it worked
Version: 0.21.0.33345 (Git) AppImage
Hash: a3c4f4bb01f5201daf666852444a8f9c5adbda8d
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
There is a small issue with intersecting faces I resolved it. You may try the modified file
https://upload.disroot.org/r/3foFK26u#O ... D9H2rfLG4=
Download is valid for 24h
Here
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.2.29603 (Git)
Python 3.10.9, Qt 5.15.8, Coin 4.0.1, Vtk 9.2.6, OCC 7.6.3
cheers
edit: with stitching on also the original file works. Seems that the intersect is very small.
Thanks,I resolved it. You may try the modified file
Here
Missed the 24H deadline. will try to see if I can resolve the issue on my installation (both answers that solved it use Linux. I am on windows. I wonder if it makes a difference)
- thomas-neemann
in my opinion freecad runs best on xubuntu lts. is this an option for you?
Not at the moment - generally I am a windows user.in my opinion freecad runs best on xubuntu lts. is this an option for you?
I have Ubuntu installed on a very old and weak PC, just for occasional use. If I get hold of a good enough PC I may install Ubuntu on it with some packages that I work with
- thomas-neemann
so you could test the current problem
Will try to install Freecad on it - it is VERY old
What does that mean?
There is no difference at all in the code for FreeCAD. The same master is used for all OS versions.
There can be differences in libraries, of course.
In my observation of the forum traffic there are at least 10X as many library problems for various flavors of Linux as there are for Windows. That is not to say that one is better than the other, however.
Many people use a great variety of FreeCAD installations quite successfully.
Gene
