Use holes as template in other designs?
M-a-x-G
Post by M-a-x-G »
OS: Linux Mint 21.1 (X-Cinnamon/cinnamon)
Version: 0.20.2.29603 (Git) AppImage
  * Assembly4 0.50.2
  * freecad.gears 1.0.0
  * Help 1.0.3
I design mostly project boxes for Arduinos (an electronic micro-controller board)...
The holes for brass inserts to screw the Arduinos on are always the same.
Is there a way that I can make the support hole arrangement a template to then copy into new designs? (or something similar)
Any hints appreciated.
Everything needs to be defined...
Re: Use holes as template in other designs?
- Establish an origin.
- Describe each hole a (x,y,z) position in respect if this origin.
- Store these data on a Spreadsheet.
- Refer to these data in another FCStd file using expressions.
This is a way, very parametric, very technical drawing derived, and reusable, as you could even have a pivot document where you store a couple of master sketches and database data and reuse across different models.
As example you could have a file that holds these data for a family of microcomputers and reuse it in every project that involve these things.
But obviously it involve some planning, but "it is engineering" so a plan is supposed to exist somewhere, better written as data than keep only in your head, usually it is more reliable, as you could keep as example a private GitHub repository with an "All right reserved" copyright (just in case some AI would spy your work to suggest solutions to other users).
Kind Regards
Shalmeneser
Post by Shalmeneser »
1) in a new file, create a 'master' sketch with circles* at the right place.
2) copy this sketch (ctrl-C, ctrl-V) in the file you need.
3) modify the attachment of this sketch to set it at the right position.
4) use those circles in new sketches with Sketcher_External.
You can also copy this 'master' sketch with PartDesign_SubShapeBinder.
(* or just (white) points for the centers)
imm
Post by imm »
Here is an example sketch with Named Constraints showing at the tree level, and 2 separate instances of the 'pattern' extruded onto a sample plane in different orientations.
mastersketch103a.FCStd
(47.94 KiB) Downloaded 20 times
