[Solved] Unable to solve an issue
ebolisa
Post by ebolisa »
As seen in the image, there's a triangular artifact in the cylinder (tube) which I don't understand what's is causing it.
Any help is appreciated.
Locale: Spanish/Spain (es_ES)
  * Assembly4 0.12.6
  * Curves 0.6.8
  * dodo 1.0.0
  * fasteners 0.4.55
  * Lithophane
  * sheetmetal 0.2.63
  * ThreadProfile 1.84.0
temp.FCStd
(570.34 KiB) Downloaded 14 times
Shalmeneser
Re: Unable to solve an issue
Post by Shalmeneser »
Sketch001 must not have a line perfectly along the inside of the cylinder (=coplanarity problem) : change offset to 14,01 mm.
You can use PartDesign_Hole for the threaded hole.
btw, find better name for your file.
Annotation 2023-06-02 141902.jpg (16.82 KiB) Viewed 611 times
Porte-manteau_SHALM.FCStd
(705.96 KiB) Downloaded 7 times
ebolisa
Post by ebolisa »
Shalmeneser wrote: Fri Jun 02, 2023 12:36 pm change offset to 14,01 mm.
Amazing what a difference 0,01 mm can do!
Thank you.
Shalmeneser
Amazing what coplanarity can undo !
2 faces/lines at the same place can be a problem for numerical computation. A clear (but small) difference can help decide what is left/right or inside/outside.
