[solved] techdraw page size
- teletypeguy
Hi all:
I am new here and have various questions, but I will start with a simple one: How do I change TechDraw to use a US-Letter (or A-size) page instead of A4?
I tried searching on this forum and it replied: "The following words in your search query were ignored because they are too common words: techdraw page size." Huh.
I am excited to get started with freecad -- I have a little bit of solidworks experience, and the Part Design wb has a familiar feel. I am an electrical engr, not mechanical, and have seen freecad mentioned a fair bit on the kicad forum where I hang out a bit.
Thanks in advance, Gil
- thomas-neemann
Re: techdraw page size
teletypeguy wrote: ↑Thu Jun 01, 2023 9:01 pm ...
I would search in google. Here's an example
site:https://forum.freecad.org techdraw page format
Hi Gilteletypeguy wrote: ↑Thu Jun 01, 2023 9:01 pm Hi all:
see TechDraw Preferences General -> Default Template
cheers
Short answer: Use a US-Letter (or A-size) template.teletypeguy wrote: ↑Thu Jun 01, 2023 9:01 pm How do I change TechDraw to use a US-Letter (or A-size) page instead of A4?
The template defines the size of the drawing page. To change the size of a page/sheet you have to exchange the template of the page.
this is a limitation of the database's internal search on texts. If you use the FreeCAD forum style, you get a separate search field invoking a search engine (almost) limited to the forum.teletypeguy wrote: ↑Thu Jun 01, 2023 9:01 pm "The following words in your search query were ignored because they are too common words: techdraw page size."
- teletypeguy
Thanks @jeno and @FBLX5 for pointing me to templates. In my install dir ...\Mod\TechDraw does not have any templates. This is v0.20.2 on win11.
Anyway, I poked around and found a letter template on the freecad github repo, downloaded (hopefully correctly) a USLetter_Landscape.svg file, saved it in a local templates dir, and changed the template in the tree, but it now looks blank: I also tried setting Preferences/TechDraw to point to the local template: When I add a new page it still looks blank, so perhaps I did not grab a valid template file after all. I will try it on linux tomorrow and see what the distro gives me in the way of templates to try. I have seen info on creating one in inkscape, I just thought there would be a selection available out of the box.
thx
thx
- wandererfan
- ANSIB_Portrait_blank.svg
- (731 Bytes) Downloaded 6 times
- ANSIB_Portrait.svg
- (21.05 KiB) Downloaded 6 times
- ANSIB_Landscape_blank.svg
- (732 Bytes) Downloaded 7 times
- ANSIB_Landscape.svg
- (28.37 KiB) Downloaded 9 times
- ANSIB.svg
- (29.77 KiB) Downloaded 5 times
- ANSIA_Portrait_blank.svg
- (781 Bytes) Downloaded 5 times
- ANSIA_Portrait.svg
- (30.96 KiB) Downloaded 6 times
- ANSIA_Landscape_blank.svg
- (782 Bytes) Downloaded 7 times
- ANSIA_Landscape.svg
- (29.15 KiB) Downloaded 6 times
- papyblaise
click the orange button and you will find more than 50 formats including US letter
- US letter.JPG (148.44 KiB) Viewed 890 times
- teletypeguy
Ahh, did not know about the orange button. But I had changed my templates dir in the prefs, so it was pointing there and I just had the one template I grabbed last night. The .../Mod/TechDraw/ location did not have a Templates subdir.papyblaise wrote: ↑Fri Jun 02, 2023 12:54 pm click the orange button and you will find more than 50 formats including US letter
@wandererfan, thanks for the files -- loaded them into my local templates dir, and then used the big orange button to select
I'll try to make a custom template or two in inkscape later (that title block is crazy-large) but I am off and running now.
Thanks all.
- teletypeguy
I am unsure how to edit post title to mark this [solved]
