Hello everybody,
I am very new to Freecad. If someone could answer this question I would know if I should pursue learning Freecad.
I work for an upholstery company and all our patterns are made out of cardboard templates. We would like to digitize the patterns. Instead of going the more common route ( taking pictures, importing them scaling them etc) I was wondering if it is possible to use a pen mouse to trace the cardboard pattern? The problem i am having is a one inch line in the real world is 8 inches long in the digital world. Is there a way to get the drawing scale to be 1:1?
I would really appreciate any input on this problem. Thanks.
tracing a pattern
Re: tracing a pattern
You can import an image, scale it and trace over it. Depending on the image it can be sensible to use Inkscapes Tracing function plus simplification for a start, which automates the tracing.Aerostatic wrote: ↑Thu Jun 01, 2023 7:01 pmI was wondering if it is possible to use a pen mouse to trace the cardboard pattern?
It would be sensible if you upload an example, so that we can better imagine what you are talking about.
If you derive a TechDraw drawing from your model, you can scale and print 1:1.The problem i am having is a one inch line in the real world is 8 inches long in the digital world. Is there a way to get the drawing scale to be 1:1?
* scanning function of a printer -> Image -> Inkscape + graphic tablet
Why do you need FreeCad ?
If you could take a picture (jpg) from a perpendicular then you could trace the object in FreeCAD, many folks start projects that way.
FreeCAD does not have any support for driving external data capture devices.Aerostatic wrote: ↑Thu Jun 01, 2023 7:01 pm I was wondering if it is possible to use a pen mouse to trace the cardboard pattern?
However, the "pen mouse" should have such support or at least links to drivers. If you can get a good digital representation then there could be several ways to import the captured data into FreeCAD for further processing.
Gene
Thank you for all your helpful insights!
