Lattice2 AttachedPlacement Error
nefarious
Post by nefarious »
I have a body that I want to use AttachedPlacement to combine several instances of a different body to.
I have done this several times before, but for some reason I get an error message 'NoneType' object has no attribute 'isDerivedFrom'
An image showing the placement around the destination object
An inage of the placement of the object to be attached
An image of what both objects showing looks like. The placement arrows are in the correct place and in the correct direction.
To make the Attachment the Stake body is the active body, it is highlighed
Then a combined select of the following in this order:
The Attachment is selected
The AttachmentPlacement is selected
and the Stake PlacementSequence is selected
and in the Lattice2 I choose Lattice PartDesign Pattern
Any help on what could be wrong?
drmacro
Re: Lattice2 AttachedPlacement Error
Post by drmacro »
Maybe the Lattice2 author @DeepSOIC might comment.
frcaduser
Post by frcaduser »
I had a somewhat similar issue when I was working with another tool. What fixed it is that the body has
to be unselected (un-bolded) but still highlighted. Double click on the active object to un-bold it then
select it without bolding it.
frcaduser
DeepSOIC
Post by DeepSOIC »
i don't know what's wrong, can you please share your project?
