Challenges adding thickness to curved array shell
JussyAD
Post by JussyAD »
I have a curved array shell that needs thickness, but I'm encountering difficulties in achieving that. Initially, I attempted offsetting the shell, but that approach didn't yield the desired results. Next, I tried offsetting the base sketches and even downgraded the B-spline to an edge, yet still no joy. Additionally, I experimented with creating a solid and applying the thickness command, but unfortunately, that didn't provide a solution either. I'm wondering if there are any alternative approaches or techniques that I could try in order to achieve thickness for the shell.
Locale: English/South Africa (en_ZA)
  * A2plus 0.4.60k
  * Behave-Dark-Colors 0.1.1
  * BIM 2021.12.0
  * CADExchanger
  * CurvedShapes 1.0.4
  * Curves 0.6.8
  * Dracula 0.0.2
  * lattice2 1.0.0
  * parts_library 1.84.0
  * Pyramids-and-Polyhedrons
  * ThreadProfile 1.84.0
car body.PNG (34.91 KiB) Viewed 1039 times
car body.FCStd
(19.1 KiB) Downloaded 16 times
drmacro
Re: Challenges adding thickness to curved array shell
Post by drmacro »
I'd expect Thickness and 3D offset to fail...
This passes Geometry check:
car body-mac.FCStd
(59.77 KiB) Downloaded 17 times
JussyAD
Post by JussyAD »
drmacro wrote: Thu Jun 01, 2023 2:35 pm I'd expect Thickness and 3D offset to fail...
Thank you. Is the thickness uniform throughout like a true offset?
drmacro
Post by drmacro »
JussyAD wrote: Thu Jun 01, 2023 3:10 pm
Probably not, I did not check the location of the scaled clone.
thomas-neemann
Post by thomas-neemann »
JussyAD wrote: Thu Jun 01, 2023 1:59 pm
If that's a solution for you, I can shoot a video for you
car body-2007.FCStd
(45.21 KiB) Downloaded 17 times
Vincent B
Post by Vincent B »
thickness doesn't like theses kind of splines. :roll:
sketches slightly changed.
car body_vb.FCStd
(952.03 KiB) Downloaded 13 times
JussyAD
Post by JussyAD »
thomas-neemann wrote: Thu Jun 01, 2023 6:09 pm
Thanks, Thomas. I'd appreciate that!
JussyAD
Post by JussyAD »
Vincent B wrote: Thu Jun 01, 2023 8:10 pm thickness doesn't like theses kind of splines. :roll:
If only it did, but I guess we have to accept workarounds until it does. This idea of offsetting part by part and then stitching it all together is brilliant and yields a valid shape too. Thanks for the advice.
freedman
Post by freedman »
I haven't tried lately but Thickness in PartDesign can work if the outside edges are made correctly, as an example this motor oil container, Thickness worked to hollow out the jug. Thickness gets complicated around the handle so I remember being surprised.
I also remember it being a bit fragile as one would expect. I know if the radius is too small Thickness will fail so Tangent surfaces become important.
You can also pipe a sketch drawn form, this would require you to draw the sheet metal thickness.
freedman
Post by freedman »
Here is a Pipe of a sketch drawn thickness. It passes BOP.
pipe66.FCStd
(156.81 KiB) Downloaded 17 times
