Selecting the lines of a sketch to pocket.
keshmaster81
Post by keshmaster81 »
I am trying to model the screw holes for this speaker:
Screenshot 2023-05-31 at 4.35.51 PM.png (613.56 KiB) Viewed 558 times
Screenshot 2023-05-31 at 4.35.57 PM.png (597.71 KiB) Viewed 558 times
Screenshot 2023-05-31 at 4.35.45 PM.png (897.4 KiB) Viewed 558 times
. The problem I am having is trying to pocket the larger hole down to the surface and the smaller hole all the way through.
OS: macOS 10.16
Version: 0.20.2.29603 (Git)
Locale: C/Default (C)
  * A2plus 0.4.60n
  * fasteners 0.4.56
  * lattice2 1.0.0
  * Curves 0.6.9
  * Assembly4 0.50.2
Hydro-1100.FCStd
(19.78 KiB) Downloaded 10 times
Bance
Re: Selecting the lines of a sketch to pocket.
Post by Bance »
Use the hole tool it has a counterbore option.
In case you want to do it manually: you need two sketches, one for the small holes going through all, one for the bigger counterbore with the appropriate depth. You can reuse your Sketch001 for the former and Sketch002 for the latter, where you have to remove the not used circles.
frcaduser
Post by frcaduser »
here is an example. Remember to select 'Reverse: true' for the pocket menu when the pocket is selected
in the Model sub-window properties.
Update: Please reference the attached tutorial on using the Polar Array tool from the Lattice2 workbench. If you're performing multiple
cuts from the same object, the Lattice2 workbench really comes in handy. What is great about the Polar Array tool is that you can define the number of array elements as well as their angular and physical distance from the center.
frcaduser
Lattice2_WB_PolarArray_Tool.pdf
(120.83 KiB) Downloaded 7 times
lattice2_WB_PolaryArray_Tool.FCStd
(37.91 KiB) Downloaded 5 times
doubleCircularPocket.FCStd
(23.24 KiB) Downloaded 7 times
papyblaise
Post by papyblaise »
I confirm the 2 answers above: Hole does not work with a non-flat or non-parallel base surface
Note that here, DatumPlan is useless for the 1st: you draw the sketch of the holes on the XY plane, and
for the counterbore also by modifying "Attachment at the right height
for my answer, I keep your 1st and its DatumPlan, I transform the 4 large diameters into construction lines (in blue) so as not to redo everything and Pocket "througt all"
and for the big ones, I make a carbon copy, swap the circles and move the bottom of the holes to the right place with "Attachment"
Hydro-1100 PPB.FCStd
(144.43 KiB) Downloaded 12 times
Hydro-1100 PPB.JPG (14.89 KiB) Viewed 363 times
Shalmeneser
Post by Shalmeneser »
:idea:
ScrewHoles_SHALM.FCStd
(715.79 KiB) Downloaded 8 times
Capture d’écran 2023-06-01 184337.jpg (61.46 KiB) Viewed 301 times
Shalmeneser
:idea:
The sketch for the hole can be far above the face.
Hydro-1100_SHALM.FCStd
(89.43 KiB) Downloaded 8 times
Capture d’écran 2023-06-01 185027.jpg (28.79 KiB) Viewed 296 times
