Fillet creates artifact in model
asimov-solensan
Post by asimov-solensan »
I don't know how to complete this design. This is the housing top for a device I'm building. The body shows no issues before the fillet (screenshot2.png).
Almost finished, I just want to create a fillet in the inside and then in the outside to give it a rounded shape on three of the four faces.
The inside screenshot looks good but it creates that ghost wall (screenshot1.png) that forbids me to work anymore with the model.
Summary: I want to create a 20mm fillet in the inside of the model (and after that another fillet on the outside).
Version info:
OS: Linux Mint 20.2 (X-Cinnamon/cinnamon)
Version: 0.20.2.29603 (Git) AppImage
Locale: Spanish/Spain (es_ES)
tapa_exterior.FCStd
(869.99 KiB) Downloaded 11 times
drmacro
Re: Fillet creates artifact in model
Post by drmacro »
The body shows no issues. Is this with the Check geometry tool?
It is likely reducing the fillet radius might fix it.
papyblaise
Post by papyblaise »
you do "Refine" = true and it's good, provided you stay in PartDesign and you will have to redo the last sketch victim of TNP
asimov-solensan
Apologies but I do not understand you.
I can set refine = true on the last pocket feature but I get the same result.
I made a refined copy of the model with the same result.
I don't understand what do you mean by "stay in PartDesign" I cannot set any fillet in that screen.
In your picture it seems you got it fixed but I'm unable to achieve.
Shalmeneser
Post by Shalmeneser »
PartDesign_Fillet 20mm inside and 23mm outside : OK.
Do you know something about TNP ? :evil: (You should not sketch upon face)
You cannot modify anything (= changing the number of faces) because you will break everything.
(You should Pad without any holes.)
Pocket017 is very brutal.
asimov-solensan
First time I hear about TNP, thanks for sharing.
I'm indeed abusing of this kind of modifications and was completely unaware of the problem.
I really appreciate your comment, I got my problem fixed and also learned how to make better models.
