[Solved] Visible line on section view could not be shown
mwlandolsi
Post by mwlandolsi »
Please see attached files, all is there. Just create a sketch with as shown in the section and revolve it.
Screenshot from 2023-05-31 12-25-45.png (35.76 KiB) Viewed 926 times
OS: Ubuntu Core 20 (X-Cinnamon/cinnamon)
Version: 0.21.0.33340 (Git) Snap 718
Hash: 568f25ba346abad8854414dfa305d51a4d8cdc9d
Python 3.8.10, Qt 5.15.7, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
  * sheetmetal 0.2.63
  * frame 0.1.0
  * Assembly3 0.12.0
  * Curves 0.6.9
  * lattice2 1.0.0
  * Render 2023.2.5
  * fasteners 0.4.56
test section revolve.FCStd
(46.83 KiB) Downloaded 9 times
thomas-neemann
Re: visible line on section view could not be shown
Post by thomas-neemann »
mwlandolsi wrote: Wed May 31, 2023 11:29 am
for this and other reasons i use persistent section cut. I dimension in the 3D window with draft and create pdf plans via print
wandererfan
Post by wandererfan »
The missing edges are a bit odd.
Turn on "Allow crazy edges"
and you will get the missing edges
bensay
Post by bensay »
@wandererfan What is the definition of a crazy edge internally?
mwlandolsi
Thank you, momently it works.
wandererfan
bensay wrote: Thu Jun 01, 2023 6:36 pm @wandererfan What is the definition of a crazy edge internally?
An linear edge on the page that is less than 0.0001 mm or more than 10 m. An ellipse that has minor diameter less than 0.0001 or a major diameter more than 10 m on the page. There something for BSplines too, maybe 10000x length to endpoint separation.
In this case there is an ellipse that has a minor that is about equal to the line thickness.
bensay
Post by bensay »
wandererfan wrote: Thu Jun 01, 2023 10:50 pm In this case there is an ellipse that has a minor that is about equal to the line thickness.
I don't get how the minor has such small length, the diameter is 13,8 mm? Or is it because it renders the hole as an ellipse instead a linear line when doing section view?
Also, maybe we should consider adding the tolerances to the preferences?
