(WORKAROUND) DXF import problem 0.21?
thomas-neemann
Post by thomas-neemann »
I can no longer import any dxf files in the current 0.21 appimage. Can anybody confirm this?
Unnamed-Cube.dxf
(6.59 KiB) Downloaded 28 times
Version: 0.21.0.33321 (Git) AppImage
Hash: 1d61ed187c9633702818c6cc5d7a1f07dd052ca8
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * BIM 2021.12.0
  * Curves 0.6.9
edit
08:40:50  Traceback (most recent call last):
  File "/tmp/.mount_33321-XCl3ss/usr/Mod/Draft/importDXF.py", line 2773, in insert
    Import.readDXF(filename)
Last edited by thomas-neemann on Wed May 31, 2023 9:37 am, edited 1 time in total.
easyw-fc
Re: DXF import problem 0.21?
Post by easyw-fc »
hi,
it seems an issue also in win release, but without error messages.
Note: legacy importer works fine
thomas-neemann
easyw-fc wrote: Wed May 31, 2023 9:31 am ...
thanks for the info, here under linux too
Syres
Re: (WORKAROUND) DXF import problem 0.21?
Post by Syres »
The last good working build I have is
Version: 0.21.0.33012 (Git)
Hash: 8f3e7451dde780ab7ac64f0eda22c9def5850889
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
  * Silk 0.1.3
  * A2plus
  * Defeaturing 1.2.0
  * CurvedShapes 1.0.4
  * MakerWorkbench 1.0.1
  * freecad.gears 1.0.0
  * Curves 0.6.8
  * toSketch 1.0.1
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.56
  * sheetmetal 0.2.63
The full error with current master I get is:
LookupError: unknown encoding: ANSI_1252
The above exception was the direct cause of the following exception:
  File "/home/john/freecad-daily-build/Mod/Draft/importDXF.py", line 2773, in insert
SystemError: <built-in method readDXF of tuple object at 0x7fa910c06840> returned a result with an error set
So I'll see if I can track down the commit.
please create an issue on github
Syres
Post by Syres »
Firstly there's already an Issue but it wasn't tested with FreeCAD's own DXF files which is alarming to say the least https://github.com/FreeCAD/FreeCAD/issues/8704 and can be re-opened as not fixed.
The PR responsible is https://github.com/FreeCAD/FreeCAD/pull/9060/files
The root cause from my testing is https://github.com/FreeCAD/FreeCAD/blob ... 3345-L3347 condition should be case insensitive as there can be ANSI and ansi based on the fact that some are imported OK but most (all my test files) that I found aren't imported.
Syres
Post by Syres »
Submitted https://github.com/FreeCAD/FreeCAD/pull/9712 but still have reservations that there are DXF files out there that open in 0.20.x but don't open in 0.21 after this change. I've hooked up an old HDD and will find some more to test.
thomas-neemann
Syres wrote: Fri Jun 02, 2023 10:47 am
thank you very much
easyw-fc
Post by easyw-fc »
Syres wrote: Fri Jun 02, 2023 10:47 am Submitted https://github.com/FreeCAD/FreeCAD/pull/9712 but still have reservations that there are DXF files out there that open in 0.20.x but don't open in 0.21 after this change. I've hooked up an old HDD and will find some more to test.
any news on this PR?
it seems a quite big issue on basic features...
Syres
Post by Syres »
easyw-fc wrote: Mon Jun 05, 2023 2:12 pm any news on this PR?
@yorik as you merged the previous PR for the issue, could you please review https://github.com/FreeCAD/FreeCAD/pull/9712 it's quite an important fix, TIA.
