hi i am using freecad 0.20.2 on windows 11
i tried installing cfd workbench which i was unable to instal then i used
https://www.youtube.com/watch?v=7I7W_H8T_JM
followed by which i did the following step
Downloading OpenFOAM, please wait...
OpenFOAM downloaded to C:\Users\satis\AppData\Local\Temp\tmpw7wn96wy.exe
OpenFOAM installer launched - please complete the installation
Downloading ParaView, please wait...
ParaView downloaded to C:\Users\satis\AppData\Local\Temp\tmptby_qc4h.exe
ParaView installer launched - please complete the installation
Downloading cfMesh, please wait...
cfMesh downloaded to C:\Users\satis\AppData\Local\Temp\tmpa9mrcqat.zip
Installing cfMesh...
Install completed
Downloading HiSA, please wait...
HiSA downloaded to C:\Users\satis\AppData\Local\Temp\tmpmk1ui1la.zip
Installing HiSA...
Install completed
Checking dependencies...
System: Windows
Runtime: MinGW
OpenFOAM directory:
C:\Users\satis\AppData\Roaming\ESI-OpenCFD\OpenFOAM\v2206
MPI was not found. Parallel execution will not be possible.
cfMesh (CfdOF version) not found
HiSA not found
Paraview executable: C:\Program Files\ParaView
5.10.1-Windows-Python3.9-msvc2017-AMD64\bin\paraview.exe
gmsh executable: C:/Users/satis/AppData/Local/Programs/FreeCAD
0.20/bin/gmsh.exe
Completed CFD dependency check
HiSA downloaded to C:\Users\satis\AppData\Local\Temp\tmp2_mas9xw.zip
Installing HiSA...
Install completed
now when try to run mesher i get the following error
20:34:42 Part to mesh:
Name: Fillet, Label: Fillet, ShapeType: Solid
20:34:42 CharacteristicLengthMax: 4.599138917286235
20:34:42 Exporting mesh refinement data ...
20:34:42 Matching boundary patches
20:34:42 Matching mesh refinement regions
20:34:42 Exporting the part surfaces ...
20:34:42 Triangulating part Fillet, patch patch_0_0
20:34:43 Populating mesh dictionaries in folder
C:\Users\satis\AppData\Local\Temp\meshCase
20:34:43 Successfully wrote meshCase to folder
20:34:43 Wrote mesh case to C:\Users\satis\AppData\Local\Temp\meshCase
20:34:46 Executing: ./Allmesh in
20:34:47 Sourcing OpenFOAM environment...
20:34:47 openfoam: windows support (mingw64) is runtime only
20:35:00 Wrapper process received terminate command
20:35:20 Part to mesh:
20:35:21 CharacteristicLengthMax: 1.0
20:35:21 Exporting mesh refinement data ...
20:35:21 Matching boundary patches
20:35:21 Matching mesh refinement regions
20:35:21 Exporting the part surfaces ...
20:35:21 Triangulating part Fillet, patch patch_0_0
20:35:21 Populating mesh dictionaries in folder
20:35:21 Successfully wrote meshCase to folder
20:35:21 Wrote mesh case to C:\Users\satis\AppData\Local\Temp\meshCase
20:35:23 Executing: ./Allmesh in
20:35:24 Sourcing OpenFOAM environment...
20:35:24 openfoam: windows support (mingw64) is runtime only
20:35:37
C:/Users/satis/AppData/Roaming/ESI-OpenCFD/OpenFOAM/v2206/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2206/platforms/win64MingwDPInt32Opt/bin/surfaceFeatureEdges.exe:
error while loading shared libraries: libOpenFOAM.dll: cannot open shared
object file: No such file or directory
unable to use cfd analysis
Moderator: oliveroxtoby
- Raedchen_im_System
Re: unable to use cfd analysis
I think that the missing MPI, cfMesh and HiSA might be the issue. Concerning MPI, there a lot of threads in this sub-forum. Concerning installation of cfMesh and HiSA, you can take a look at my first video tutorial: https://www.youtube.com/watch?v=OS4sbbBtZUw&t=369s
cfMesh and HiSa are compiled, this lasts very, very long. You can check the result in the log-files, please refer to my tutorial. In the tutorial, the "old" version of openFoam (blueCfd) was used, that has changed now to ESI-OpenFoam.
For openFoam for windows, there are 2 versions available: The version v2012 and the version v2206. If you install the version v2206, please make sure that each path is set correct.
- adrianinsaval
I'm asuming you installed this one: https://www.openfoam.com/download/openf ... ompilation
which says:
which says:
meaning you can't install hisa or cfmesh on it if I'm not mistakenThis version does not support compilation of OpenFOAM or dynamic code
- oliveroxtoby
That's not actually the case. We provide pre-compiled binaries for this platform.adrianinsaval wrote: ↑Wed May 31, 2023 6:59 pm I'm asuming you installed this one: https://www.openfoam.com/download/openf ... ompilation
which says:meaning you can't install hisa or cfmesh on it if I'm not mistakenThis version does not support compilation of OpenFOAM or dynamic code
