Pocket around a hole don't take effect
jiandingzhe
Post by jiandingzhe »
As shown in this snapshot, there already exists a hole that is Pocketed from the other side of the wall (thickness is not even), and I want to make a "step" around it by Pocketing Sketch023.
(Though the face is de-facto planar, I still need to create DatumPlane001 to hold Sketch023, otherwise it raises "You need a planar face as support for a sketch".)
When I try to make the "step" by creating a new Pocket using Sketch023, it just take no effect at all, no matter how much length is set. Is it caused that there are limits for holes inside pocket path? If so, how can I create the step around any hole?
papyblaise
Re: Pocket around a hole don't take effect
Post by papyblaise »
I do not understand, Hole is precisely a tool to make a milling around a hole
but maybe also just make the "Reverse" hole
without file, we can not say more
M4x
Post by M4x »
Please share your FreeCAD version information and file with us. Details in the big red banner at the top. Thanks!
Shalmeneser
Post by Shalmeneser »
jiandingzhe wrote: Mon May 29, 2023 1:44 pm "You need a planar face as support for a sketch"
Do you know TNP ?
M4x
Post by M4x »
Let us first handle the initial question ;)
GeneFC
Post by GeneFC »
As Papy said, you probably need to reverse the direction of the hole. Use the checkbox in the Pocket operation.
Depending on what you plan to do further to this model it may be easiest to just create the sketch on a standard plane. Move it to where it is wanted. No need to "attach" to anything else.
This is not the paragon of fine modeling practice, but it usually works in simple cases.
Gene
jiandingzhe
papyblaise wrote: Mon May 29, 2023 2:15 pm I do not understand, Hole is precisely a tool to make a milling around a hole
I will try the Hole tool.
The file exceeds forum's size limit. I will try to make a smaller demonstration project later.
jiandingzhe
Shalmeneser wrote: Mon May 29, 2023 3:03 pm
Do you know TNP ?
I made the model in a sequential way and did not change sizes, so possibly not TNP?
jiandingzhe
M4x wrote: Mon May 29, 2023 2:22 pm Please share your FreeCAD version information and file with us. Details in the big red banner at the top. Thanks!
I'm using a very new 0.2 series version that is downloaded one week ago.
The file exceeds forum's size limit so I just give a screenshot. I will try to make a smaller demonstration project later.
M4x
Post by M4x »
Please follow the advice in the linked thread. We made it very convenient to post all the needed FreeCAD version information.
