Creation of spiral sketch to part
holland237
Post by holland237 »
Good morning,
I am trying to create a spiral part from a sketch, but seem to be doing something wrong since when i try to extrude my sketch it doesn't work. I've attached the software details and screenshot of what my sketch looks like - i'm trying to extrude this in the z-direction into a tube like part. I think it may be to do with the geometry being several lines, but i don't know- sometimes i receive the error 'wire is not closed'. I created my spiral 'sketch' in part>create primitives and then the spiral option, but i beleive i need to turn the lines into a suitable sketch before i can proceed. I receive the message ' selected object must belong to an active body - consider using a shapebinder', so i guess i must have to first create a body.....but i'd like to request some assistance on how do i access the option to sketch the spiral? In summary, i think i have some of these steps in the wrong order but can't figure out where i've gone wrong..... Thank you for any tips you can offer!
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
Spiral sketch_290523.PNG (32.71 KiB) Viewed 543 times
NewJoker
Re: Creation of spiral sketch to part
Post by NewJoker »
Can you share the .FCStd file ?
Bance
Post by Bance »
Is this what you are trying to do?
overlap cyl.FCStd
(24.84 KiB) Downloaded 7 times
papyblaise
Post by papyblaise »
it is a process worthy of alchemy:
you create your 2 concentric spirals, they are B-splines Draft Wb
you go to Draft Wb, you transform each spiral into a sketch with the tool provided for this purpose
you go to Sketch Wb and you fuse the 2 sketches
you go to PartDesign, create a body and slip this last sketch into it, you open it and close the 2 ends with a constrained line at the 2 ends to have a closed sketch
you can extrude (Pad)
Note, you can stay in Sketch Wb and extrude in Part Wb
spiral pin.FCStd
(37.12 KiB) Downloaded 7 times
spiral pin.JPG (45.46 KiB) Viewed 488 times
holland237
Wow...!
Thanks for the quick responses everyone! I've followed the steps and have created the part as you have it on your screens.....thanks again this is very helpful!
