Hi here,
Please help me with Lamp Shade Frame.
I have hoop and stick and then using Polar Pattern I duplicate stick 3 times.
The issue I have is shown on the picture. You can also see my FreeCAD file in the attachment.
Please advise how to fix this defect.
Thank you,
Vitaliy
Additive pipes overlapping issue
Re: Additive pipes overlapping issue
Reduce values theses 2 parameters, could give a better display.
- Capture.JPG (31.25 KiB) Viewed 531 times
Part_CheckGeometry shows no problem.
* You can try to modify the quality of visualiazation : Body > View > Angular Deflection -or- Deviation
* I would do the circle with PartDesign_Revolution
* I would avoid coplanarity with different radius for circle and line
* I would attach the circle to the line (to be normal and create a perfect cylinder).
but any of these modification provide a perfect solution.
- lamp_SHALM.FCStd
- (67.77 KiB) Downloaded 7 times
- thomas-neemann
Many thanks for help and additional recommendations.
Great tool with awesome community!
