Color Loss - it gets worse - no sheet metal edit!
bobH2
Post by bobH2 »
Hey!
In viewtopic.php?p=684071#p684071 I presented a sample that lost all Color.
The attached is basically the same sample but demonstrating how a simple save can prevent any further editing of Sheet Metal attachments.
Normally, when you right click on a bend, you can edit its attachment position. When the file gets messed up, the edit ability is lost:
This is a horrible bug - all bends have to be deleted and recreated. Is there a workaround? If not, If someone can confirm I will pass this on to GitHub.
Instructions are in the imbedded "Text document". For more info see the link above to p6840071.
I believe the problem is connected somehow with the use of Text Documents. I have found these invaluable for keeping notes and storing coordinates when reimporting step files of other parts that have to evolve. Could use the spreadsheet but the text is faster.
Thanks,
Bob.
NoSheetMetalEdit.FCStd
(16.13 KiB) Downloaded 21 times
Re: Color Loss - it gets worse - no sheet metal edit!
Did you try with the latest versions of FreeCAD and SheetMetal? Full FreeCAD infos are always welcome.
bobH2
Post by bobH2 »
chrisb,
Yes - both 0.20.2 and 0.21.0 and SheetMetal 0.2.63.
The easy fix for this is likely just have FreeCAD always save any "Text Documents" automatically when the rest of the project is saved. I can't see how someone would want to save a project but not save any text changes. If in doubt, it can be an option in preferences.
Thanks,
Bob.
bobH2 wrote: Fri Jun 02, 2023 10:31 pm chrisb,
Not to be pedantic but here:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
You will find the correct way to post Full FreeCAD info that are way too much detailed than the info supplied above.
Sorry for not posting an example but my PC internet connection is not working due to technical works.
Roy_043
Post by Roy_043 »
Confirmed.
After changing the embedded text document and pressing "X" you are prompted to save the document twice. It is the 2nd save that causes the problems.
The problems can easily be avoided by using Std_Save after changes to the text document. Or by ignoring the 2nd prompt.
OS: Windows 8 build 9600
Version: 0.21.0.33321 (Git)
Hash: 1d61ed187c9633702818c6cc5d7a1f07dd052ca8
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * sheetmetal 0.2.59
bobH2
Post by bobH2 »
chrisb, onekk
OS: Windows Server 2016 Version 1809
Locale: English/Canada (en_CA)
  * Assembly4 0.50.2
  * Curves 0.6.9
  * fasteners 0.4.56
  * Help 1.0.3
  * MeshRemodel 1.8919.0
  * sheetmetal 0.2.63
  * Trails 2022.1.0
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
  * Assembly4 0.50.2
  * Curves 0.6.9
  * fasteners 0.4.56
  * Help 1.0.3
  * sheetmetal 0.2.63
  * Trails 2022.1.0
I'll try to remember to post the versions better in the future.
Roy_043,
Thank you for confirming. And yes, when the project is saved through the menu as you suggest, there doesn't seem to be any problem. Problem is, i don't always remember to do that.
I have posted this in Github: https://github.com/FreeCAD/FreeCAD/issues/9730
Thanks,
Bob.
