Draft Constrain Not Working
arxerxes
Post by arxerxes »
Draft Constrain not working when Shift key pressed. GIF attached. FreeCAD version info below. Please note that I am running FreeCAD installed on Windows 11 Arm64 on Parallels 11 on an M1 Macbook Pro 16 inch.
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
  * BIM 2021.12.0
  * CADExchanger
  * Curves 0.6.9
  * fasteners 0.4.56
Roy_043
Re: Draft Constrain Not Working
Post by Roy_043 »
You have to keep the Shift key held down. Are you doing that?
arxerxes
Post by arxerxes »
Roy_043 wrote: Sat May 27, 2023 6:40 pm You have to keep the Shift key held down. Are you doing that?
Yes - pressing the Shift key does not have any effect. No matter how long I press it.
Roy_043
Post by Roy_043 »
To clarify: the key must be held down while you create your geometry.
arxerxes
Post by arxerxes »
Roy_043 wrote: Sat May 27, 2023 6:59 pm To clarify: the key must be held down while you create your geometry.
Yes. I know that. I have done this before.
This seems to be an issue with 0.20 version as well.
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
  * BIM 2021.12.0
  * CADExchanger
  * Curves 0.6.9
  * fasteners 0.4.56
It doesn't seem to be an issue with Shift key or FreeCAD not recognizing the shift key. FreeCAD annotation text box does capitalization when shift key is pressed. Is anyone working with Windows 11 on Parallels for Mac?
