arxerxes
Posts: 61 Joined: Sun Jan 31, 2021 2:07 am
Post
by arxerxes » Sat May 27, 2023 5:26 pm
Draft Split command shows an error "- <class 'TypeError'>" and in addition to that makes the lines slightly tilts. GIF file attached. You can see how Y coordinate of the lines have changed after the split.
The FreeCAD build below.
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
* BIM 2021.12.0
* CADExchanger
* Curves 0.6.9
* fasteners 0.4.56
Draft SplitA.gif (789.66 KiB) Viewed 656 times
Roy_043
Posts: 8552 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Sat May 27, 2023 6:42 pm
The 'tilting' issue is known. But maybe should be fixed. See
Draft_Split .
I can't reproduce the class error.
OS: Windows 8 build 9600
Version: 0.21.0.33303 (Git)
Hash: 5b075a9938b78076fdde9034de4a05685e42690e
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C) [ OS: Dutch/Netherlands (nl_NL) ]
arxerxes
Post
by arxerxes » Sun May 28, 2023 12:01 am
Roy_043 wrote: ↑ Sat May 27, 2023 6:42 pm
Draft_Split .
By the way the below 0.21 version installed directly on a Windows 10 Intel based laptop does not have this issue.
Version: 0.21.0.32929 (Git)
Hash: 1dcc58c4b1c51c50215639ca58326f6b69867743
Locale: English/Canada (en_CA)
* A2plus 0.4.60k
* Assembly4 0.50.1
* BIM 2021.12.0
* Curves 0.6.8
* fasteners 0.4.56
* freecad.gears 1.0.0
* Help 1.0.3
Posts: 54213 Joined: Tue Mar 17, 2015 9:14 am
Post
by chrisb » Sun May 28, 2023 4:32 am
arxerxes wrote: ↑ Sat May 27, 2023 5:26 pm
Please upload a preferably simple file showing the issue together with a description where to split, so that we can reproduce under the same conditions.
