Unfortunately, the cabinet is drawn with the door being closed. I would like to remove the door. Optimally, the door would be an independent object whose visibility I can toggle on/off later, but it would also be fine, if the door was deleted entirely, if that was easier.
I selected the Part object and used the tool Draft_Downgrade as I assumed that this would be the right tool. After some processing time, I got a glimpse of hundreds of surfaces in the project browser, but then the following error message appeared
16:58:07 ----------------
GuiCommand: Downgrade
Downgrade objects
Mehrere Flächen gefunden: Werden getrennt
Downgrade objects
Mehrere Objekte gefunden: Subtrahiere sie vom ersten Objekt
<App> Document.cpp(3473): Recursive calling of recompute for document Rittal_Cabinet_1376_000__exploded_
If I press "Ctrl + Z", then the individual surfaces reappear and the cabinet looks right. I can even select individual surfaces. But as soon as I try to do anything with them (e.g. delete a surface), the same error message appears and I end up with a single Part "Subtracted" again.
What am I doing wrong? Isn't Draft_Downgrade the correct tool? How do I remove the doors from the cabinet?
As the file exceeds the size for attachments, the projects can be downloaded from Google Drive:
- After importing the IGES file (one Part object): https://drive.google.com/file/d/1xn9VV6 ... sp=sharing
- After using Draft_Downgrade and "Ctrl+Z" (exploded): https://drive.google.com/file/d/1YH9SSE ... sp=sharing
