preferences of Path launch also Part/PartDesign preferences
david69
Post by david69 »
I don't remenber that launching Path wb, we alos see the preferences of Part/PartDesign.
the wiki doesn't say that.
@kaktus to inform you too in case of we need to open a PR.
GeneFC
Re: preferences of Path launch also Part/PartDesign preferences
Post by GeneFC »
david69 wrote: Fri May 26, 2023 1:27 pm I don't remember that launching Path WB, we also see the preferences of Part/PartDesign.
The wiki doesn't say that.
Can you explain what you mean? I do not see anything strange when looking at Preferences.
Gene
david69
Post by david69 »
GeneFC wrote: Fri May 26, 2023 2:57 pm Can you explain what you mean?
open FreeCAD and launch only Path wb.
go to the Preferences. I don't expect to also see the preferences of Part/PartDesign:
Capture d’écran du 2023-05-26 20-24-07.png (18.32 KiB) Viewed 995 times
Path_Preferences doesn't talk about that and I don't remember that too but as I am not a user, only translator, I am not sure.
GeneFC
Post by GeneFC »
There was some rearrangement of the Preferences over the past couple of months, so any changes are likely the result of that adjustment.
I think Part WB is always active, so the Part/PartDesign Preferences will always appear.
I do not believe the Path WB has any role in this behavior.
Gene
Path uses something from PartDesign and thus it is imported and shows in the preferences. This can happen with other workbenches too, and may be worth mentioning in the wiki, but it can also be seen as some implementation detail which you don't have to worry about.
david69
Post by david69 »
I don't really worry only wanted to clarify (my memory can play with me).
GeneC has more or less answer to my questionning.
GeneFC wrote: Sat May 27, 2023 12:52 am I think Part WB is always active
not necessary, if you launch Arch Wb, Draft preferences are shown too but not Part ones for ex. same thing with Mesh wb.
thank you for your feedback.
GeneFC
Post by GeneFC »
david69 wrote: Sat May 27, 2023 6:41 am not necessary,
The core of the Part WB is always active. Sorry if I suggested that the Path WB Preferences must always be shown.
Gene
