The Image WB has moved to File-Import. The attached shows Mangojelly's image options and mine (which has far fewer options!).
How can I get all the options showing?
Image WB
Image WB
- Mangojelly.svg
- (205.22 KiB) Downloaded 21 times
- SandyImage.png (18.18 KiB) Viewed 756 times
Re: Image WB
Use the same version of FC?
Re: Image WB
Away from computer for a day or two. But latest version of Freecad was loaded earlier today so it is the current version
Re: Image WB
1) It would need the full FreeCAD infos in both cases.
2) you compared apples with pears, as we say here: You should also look at the Data tab properties in your case. They often show more properties, and sometimes they show less.
Re: Image WB
Thanks Chris. Will look at it when I get home
Re: Image WB
Got it worked out.
Right click on image file in Combo View and select "Change Image".
