Both cfMesh and snappyHexMesh seem to make rectangular cells but with a diagonal through the cell. Is there a way to remove that diagonal so the cell are pure hexagonal cells with all faces at near 90 degrees (at least near center)?
I am used to using SimScale and in that software, snappyHexMesh always seems to generate cells without any diagonal.
Diagonal Through Rectangular Mesh Cell
Moderator: oliveroxtoby
- Cube.FCStd
- (9.61 KiB) Downloaded 27 times
Re: Diagonal Through Rectangular Mesh Cell
This is just a matter of visualization. If you open the mesh in ParaView, it will look normal: viewtopic.php?t=74612
Ok, then is there a way to turn that off in the visualization? It is difficult to tell where the "real" mesh is.
I don’t think it can be disabled. But you can press the button to open the mesh in ParaView so you don’t have to import the mesh there manually.
- oliveroxtoby
This isn't going to happen any time soon as neither the FEM mesh visualisation nor the mesh workbench are currently able to display the polyhedral cells/faces generated at the refinement boundaries.
