How to find a boolean child
GigiG
Post by GigiG »
Hi, is there a way to find a hidden boolean child from a 3D view selection? As an example, the cylinder shown in the figures. If I select the resulting hole, only the last resuting Part will be highlighted.
Screenshot at 2023-05-25 19-09-48.png (201.18 KiB) Viewed 976 times
Screenshot at 2023-05-25 19-09-25.png (197.23 KiB) Viewed 976 times
OS: Linux Mint 21.1 (MATE/mate)
Version: 0.21.
Branch: unknown
Hash: 1faf86c3da12c1712e1d5ec015721d9aa02f8672
Python 3.10.4, Qt 5.15.3, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.1
  * Manipulator 1.5.0
  * Dracula 0.0.4
  * ExtremeProDark 2.8.0
  * Glass
  * Render 2023.2.5
Shalmeneser
Re: How to find a boolean child
Post by Shalmeneser »
Give name for each step ?
PardDesign wb construction tree is easier to find something.
drmacro
Post by drmacro »
Do you know the name of what you seek? Right click on the document name in the tree view and select Search.
papyblaise
Post by papyblaise »
I guess you are a beginner, I think that seeing that you only use predefined elements
it would be easier by drawing sketches and making pads or pockets
to answer: a quick way to search is to go back down the tree by hiding the successive Cuts, the cylinder you are looking for will reappear at one step
GigiG
Post by GigiG »
Thanks all, yes, in this case it would have been better to use a sketch but I'm actually wont to learn booleans.
thomas-neemann
Post by thomas-neemann »
GigiG wrote: Thu May 25, 2023 5:17 pm
this happens to me too from time to time. then i load the part in realthunder and move the mouse over the parts in the parts tree until the desired part lights up
GigiG
Post by GigiG »
Thanks a lot, I'll try. I'm new to Freecad branches and it seems to me that Realthunder is a Freecad branch. Which is the more effective way to install it and update it frequently?
thomas-neemann wrote: Fri May 26, 2023 8:03 am
thomas-neemann
GigiG wrote: Fri May 26, 2023 10:22 am
I wouldn't install it. i use it as appiumage in a linux virtualization because it caused problems on my native systsem with the master. I would only use realthunder for such purposes, or for visualization with shadows, etc
https://github.com/realthunder/FreeCAD/releases
thomas-neemann wrote: Fri May 26, 2023 8:03 am this happens to me too from time to time. then i load the part in realthunder and move the mouse over the parts in the parts tree until the desired part lights up
Does the object - in your case "Zylinder" - show on mouse hover even if it is hidden?
thomas-neemann
chrisb wrote: Wed May 31, 2023 6:16 pm
Yes, if I move the mouse over hidden parts in the parts tree, they are also highlighted in the 3D window (in realthunder)
