JorgeFernandes
Post
by JorgeFernandes »
Hi everyone.
How can I export a loaded step as a .dae file?
path = 'bim.step'
s = Part.Shape()
s.read(path)
To stl I can do:
Is there something similar to date?
My system:
OS: Ubuntu 22.04.2 LTS (ubuntu:GNOME/ubuntu-xorg)
Version: 0.19.
Python version: 3.10.2
Qt version: 5.15.2
OCC version: 7.5.1
Thanks in advance.
Roy_043
Post
by Roy_043 »
If you do the export manually, you will see usable Python code in the Python console.
JorgeFernandes
Post
by JorgeFernandes »
Roy_043 wrote: ↑Wed May 24, 2023 7:59 pm
Thanks for the reply.
I already try that but I can't figure out the proper way to make it work.
Roy_043
Post
by Roy_043 »
import Part
import importDAE
path = "C:/Downloads/Test.step"
s = Part.Shape()
s.read(path)
obj = Part.show(s) # Create a document object.
importDAE.export([obj], "C:/Downloads/Test.dae")
JorgeFernandes
Post
by JorgeFernandes »
Roy_043 wrote: ↑Wed May 24, 2023 8:15 pm
import Part
import importDAE
s = Part.Shape()
s.read(path)
Thanks a lot. I'll try it and see if it works.
JorgeFernandes
Post
by JorgeFernandes »
import Part
import importDAE
s = Part.Shape()
s.read(path)
This works perfectly. Thanks again for the help.
I have another question:
I can change the resolution, how can I do that with code?
