QSocketNotifier: Can only be used with threads started with QThread
PrzemoF
Post by PrzemoF »
I upgraded fedora to 37 and FreeCAD now produces this:
$ FreeCAD
FreeCAD 0.21.0, Libs: 0.21.0Rpre_33268.fc37 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2023
QOpenGLFunctions created with non-current context
Wayland does not support QWindow::requestActivate()
OS: Fedora Linux 37 (Workstation Edition) (GNOME/gnome)
Version: 0.21.0.pre_33268.fc37 (Git)
Build type: Unknown
Python 3.11.3, Qt 5.15.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * BIM 2021.12.0
  * MeshRemodel 1.8919.0
  * Help 1.0.3
  * ExtremeProDark 2.7.8
Bottom of the screen also shows error.
Screenshot from 2023-05-23 22-53-07.png (115.97 KiB) Viewed 2894 times
WARNING: there is a chance that it's my local problem as the system went through some bumps during the fedora upgrade.
PrzemoF
Re: QSocketNotifier: Can only be used with threads started with QThread
Post by PrzemoF »
Same on:
Version: 0.21.0.pre_33274.fc37 (Git)
Build type: Unknown
  * BIM 2021.12.0
  * Help 1.0.3
It must be related to your system because FreeCAD doesn't use QSocketNotifier anywhere. And the warnings about wayland come from your system too since FreeCAD doesn't directly access the API of the display server.
Now the question is whether there is a simple way to filter the warnings. If you build FreeCAD yourself can you add this line to void messageHandler(QtMsgType type, const QMessageLogContext &context, const QString &msg):
Base::Console().Message("%s\n", context.category);
and report back what the output is?
what about the wayland error?
openBrain
Post by openBrain »
wmayer wrote: Wed May 24, 2023 7:52 am can you add this line to void messageHandler(QtMsgType type, const QMessageLogContext &context, const QString &msg):
Wouldn't that be good to add this in the debug builds?
I have prepared a PR to show the category in parentheses. This way we can easily add it to the ignore list if needed.
https://github.com/FreeCAD/FreeCAD/pull/9648
PrzemoF
Post by PrzemoF »
Most likely there is problem with my system I'm unable to boot to GUI now.
PrzemoF
Post by PrzemoF »
On fedora we miss qqc2-desktop-style - I'll add that to the dependencies. The wayland error - I switched to xorg for now, but I'll come back later.
Done.
