Page 3 of 5
Re: Headers in Treeview could we remove them?
Posted: Thu May 25, 2023 11:58 pm
by obelisk79
chrisb wrote: ↑Thu May 25, 2023 10:42 pm
That's probably what it's all about: If the property is filled out, then because someone
wants to show it.
Just for clarity, I don't think it "needs" to be removed given the current state of the tree-view, but changing it to a tool-tip style popup in my mind still seems like a better way to display such information.
Posted: Fri May 26, 2023 12:43 am
by sliptonic
obelisk79 wrote: ↑Thu May 25, 2023 4:09 pm
If the property is filled out, it will take up UI space,
wants to show it.
With all due respect, @chrisb, I think we're pole-vaulting over mouse poop.
Take the stupid thing out and if users complain (a lot) put it back in.
Better yet, take the time to understand
why a user wants it and make an even better feature.
The way to have a more efficient user interface isn't to avoid making mistakes. It's to iterate faster!! Try stuff. Learn something and move on.
User interface shouldn't be about avoiding every possible criticism, it should be about trying out new ideas fast and throwing away the bad ones.
Posted: Fri May 26, 2023 5:08 am
by chrisb
sliptonic wrote: ↑Fri May 26, 2023 12:43 am
You may be right with the mouse poop, and I will not insist on keeping it, because I used these fields only very few times myself. But I have seen some models here, where it was used extensively, and seeing it I thought "wow, that's a well documented project", of course accompanied by the less comfortable feeling that I should do more with my own projects.
(These models where not about the field discussed here and I see no chance to find them.)
So let's tackle it from the other side: We all know that well documented (bigger) projects are good projects. The questions arising are
1) Should additional information be held in the FreeCAD file?
2) If so, where should it be stored.
I have for myself a directory for each project, where I may have a README file with extended information, usually not per tree entry, but rather something like the math behind, printer settings, machine setups, where to by the wood, ...
Finally it may be interesting, that there was recently a discussion about adding information to individual sketcher constraints.
Posted: Fri May 26, 2023 6:29 am
by FBXL5
sliptonic wrote: ↑Thu May 25, 2023 3:15 pm
Still, since Label2 is a hidden property and, it appears, hardly anyone is using it for descriptions
MisterMaker wrote: ↑Wed May 24, 2023 7:39 pm
Yes! Label2=description.
I often thought about the use of Label2 and description and I have never realised that the are connected.
I would have used it quite frequently if I only knew. I've had a look at the Tree view Wiki page and couldn't find description of this connection.
Instead of removing the Description column, I'd prefer to be able to edit Label2 directly in the Tree view, a menu entry "Description" under "Rename" at least. And a better visible documentation of the connection between Label2 and the Description column in the Wiki
Edit: Wiki is updated. Maybe
@Roy_043 likes to fine-tune...
Posted: Fri May 26, 2023 1:09 pm
by Roy_043
Not sure if fine-tuning is the correct term, but I have made an edit.
Posted: Fri May 26, 2023 3:27 pm
by MisterMaker
Roy_043 wrote: ↑Fri May 26, 2023 1:09 pm
Tell me your secrets!?
Posted: Fri May 26, 2023 4:39 pm
by FBXL5
Thanks! To me it seemed like the general description would fit the Labels & Attributes section but I wasn't sure (or if it would be better placed in some other section).
Posted: Fri May 26, 2023 9:20 pm
by adrianinsaval
FBXL5 wrote: ↑Fri May 26, 2023 6:29 am
you can edit the description in the tree view but it's not very intuitive, you have to click on that field then press F2
Posted: Fri May 26, 2023 10:06 pm
by FBXL5
adrianinsaval wrote: ↑Fri May 26, 2023 9:20 pm
That doesn't work on my MacBook
Posted: Fri May 26, 2023 10:12 pm
by adrianinsaval
Try using whatever is the normal shortcut for renaming something in macOS
