Headers in Treeview could we remove them?
MisterMaker
Post by MisterMaker »
So what is up with the headers in the treeview?
I kinda feel that it's useless. @realthunder also removed it in his linkstage branch.
I managed to remove it with some qss wizary. But it might and probably breaks something somewhere else that uses Qtreeview?
There is also a boolean and the docs actually say you can disable it but no where it is mentioned about how to do this true qss.
With code:
QTreeWidget QHeaderView::section {
  background-color: transparent;
  border: 0px solid #696968;
  color: transparent;
  margin: -100%;
@chennes
chennes
Re: Headers in Treeview could we remove them?
Post by chennes »
You could submit a PR to switch the default for that preference to "False" (though it won't get reviewed until after 0.21 is released).
Chris Hennes
Pioneer Library System
obelisk79
Post by obelisk79 »
On that same token, what value/use-case is there for the description column? Is it something which could be disabled via a property? It takes up unnecessary screen space in my opinion. I'd rather see that text be applied to a tooltip for treeview items anyway.
Sort of along the same lines of using good naming conventions vs commenting everything in source code. I don't even know how to make entries into the description column (not that I've tried hard).
+1 for removing the headers and +1 for a preference to show the description on tooltips only
sliptonic
Post by sliptonic »
obelisk79 wrote: Wed May 24, 2023 2:31 pm On that same token, what value/use-case is there for the description column? Is it something which could be disabled via a property? It takes up unnecessary screen space in my opinion. I'd rather see that text be applied to a tooltip for treeview items anyway.
I can't recall ever seeing anything in that column. Let's kill it and see if anyone screams.
I've seen people using it and have done so myself when I felt a feature could use an explanation, that being said it's not worth the lost real state to me. I say make it optional (off by default), and only show the headers when the description column is visible.
paddle
Post by paddle »
+1 to remove the headers and at least disable description by default.
The root of the tree called "Application" could also be removed. It useless.
MisterMaker
Description is for label2.
Since it doesn't have the same namr it's even a better reason to remove. Or at least rename it.
sliptonic
Post by sliptonic »
MisterMaker wrote: Wed May 24, 2023 3:45 pm Description is for label2.
Label2 as a property is hidden by default. What's it for?
MisterMaker
sliptonic wrote: Wed May 24, 2023 3:53 pm
Add a description, pretty usefull actually but not so good implemented, definitely not something that we should hide. I remember I had a discussion about this a while ago. But nothing came out of it.
