Ruler on mesh gives incorrect distance
Moderator: oliveroxtoby
markinca
Post by markinca »
If I use the ruler on the part, dimensions are correct. However, when I use it on the mesh from the part, the values are over 200x too big. Also, the label is placed well off the screen so you have zoom out 200x to see it. So there appears to be scaling issue.
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
  * CfdOF 1.22.9
  * Help 1.0.3
Pipe Only Example.FCStd
(16.68 KiB) Downloaded 29 times
hooshsim
Re: Ruler on mesh gives incorrect distance
Post by hooshsim »
I can not duplicate your issue. Part ruler and mesh both display the same info without zooming in.
markinca
Post by markinca »
Thanks for the reply.
I think I figured out what happened. When I selected points on the desired face surface, one point was very close to the edge and if I select that point and happen to miss the edge of the front face by just a little bit, it will assume that point is somewhere deeper into the mesh and give a wrong measurement. I just need to be more careful when selecting edge points.
The fact that triangulation is added to the hex-dominant mesh does not help matters any.
