ModuleNotFoundError: No module named 'PyQt5.QtWidgets', but in QtWidgets'
from PySide2.QtWidgets import QWidget
Thank you for your reply! The function I need to realize is not supported by pyside, so I used pyqt.Syres wrote: ↑Tue May 23, 2023 10:32 am Are you using self compiled or an AppImage? I thought the standard on 0.19.x was:
