Calling on all developers to check the 0.21 Release notes...
Jolbas
Re: Calling on all developers to check the 0.21 Release notes...
Post by Jolbas »
Roy_043 wrote: Thu Jun 08, 2023 7:55 am @Jolbas I have updated the Navigation_Cube page, and also the item on the Release_notes_0.21 page. If you have the time, please check. Thanks.
Thanks! Looks very good. I will have a look att those offset parameters.
Jolbas
Post by Jolbas »
@Roy_043 OffsetX and OffsetY works as intended in my tests. OffsetX is added to the margin to the left or right side of the window and OffsetY is added to the margin to the top or bottom. What happened in your test and what is your expected behaviour?
Roy_043
Post by Roy_043 »
Only the position of the Navigation Cube in the current 3D view is updated. Create a new view or restart FreeCAD and OffsetX and OffsetY are ignored. I would also expect that dragging the cube updates these parameters.
OS: Windows 8 build 9600
Version: 0.21.0.33321 (Git)
Hash: 1d61ed187c9633702818c6cc5d7a1f07dd052ca8
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C) [ OS: Dutch/Netherlands (nl_NL) ]
Jolbas
Post by Jolbas »
Ah. I submitted a fix for the first problem https://github.com/FreeCAD/FreeCAD/pull/9746. The second suggestion needs some elaboration and discussion. Maybe start a separate thread or a github issue for that.
Roy_043 wrote: Thu Jun 08, 2023 4:27 pm I would also expect that dragging the cube updates these parameters.
I don't see this as desired behavior, dragging the navicube is purposefully a temporary modification, perhaps to move it out of the way for a short time.
adrianinsaval wrote: Thu Jun 08, 2023 5:59 pm
In other places changes via GUI change the preferences as well, and it seems quite natural to move the navicube via the GUI to its desired position.
