Version 0.20.2
Rev. # 29603 (Git)
Release Date 2022/12/07 02:35:37
OS Windows 10 Version 2009
Word Size 64-bit
I am attempting to apply a draft angle to an enclosure by using the draft tool from the Part Design workbench. If I apply the draft angle to the enclosure from the inside, it will work as highlighted by the screenshot attachment. However, still receiving the error 'Adding face failed on
Face9. Omitted.' When I attempt to apply the same draft angle but on the outside surface, I get the same error, but the draft angle is not
applied.
Note that the neutral plane is the top perimeter surface.
Why would the draft tool not work for the outside surface?
frcaduser
Part Design: Draft Angle Tool [Solved]
- draftAngleInside_01.png (19.4 KiB) Viewed 258 times
- enclosureDraftAngle.FCStd
- (32.54 KiB) Downloaded 15 times
- draftAngleInside.png (28.96 KiB) Viewed 291 times
