same macro, same version of freecad, but very different meshes between linux and windows.
Moderator: bernd
Re: same macro, same version of freecad, but very different meshes between linux and windows.
on my ubuntu VM, I downloaded freecad 0.20.2 with the AppImage ( https://www.freecad.org/downloads.php ), and so I can't have access to the ''deep'' parameters (because I don't have access to the freecad sources hidden in the .AppImage file)
salut,
@theodoresyroco the red banner gives some clues and in particular how to collect/give info about your FreeCADs.
here is a link showing that for the two installations.
viewtopic.php?p=423310#p423310
OS: Ubuntu 20.04.5 LTS (XFCE/xubuntu)
Version: 0.20.2.29603 (Git) AppImage
always is, the problem remains there. But I see the problem more clearly now.
As I said, I have two installations of Freecad whose info is on the first message. The first installation is on Windows and the second one is on my linux VM ubuntu.
In order to locate precisely the problem I did the following test:
From my freecad on Linux I created a wing object, an analysis with a netgen mesh of which here is the configuration and the result (1st image : mesh of the wing in my Linux FreeCAD). I save the FCStd file and I open it on my FreeCAD Windows (2nd image : mesh of the wing after opening in my Windows FreeCAD the file from my Linux FreeCAD). Then I recompute the mesh without changing the parameters (3rd image : mesh of the wing after opening in my Windows FreeCAD the file from my Linux FreeCAD having recalculated the mesh without changing the parameters ). As you can see there are more than twenty times as many points in my mesh on my Freecad Linux which makes my calculations much too heavy. I would like to get the same mesh on my FreeCAD Linux as on my FreeCAD Windows. Is this message clearer? Do you have an idea to help me?
Thanks
Theodore
I realize that there was some information missing at the beginning and that my problem was not well defined. I hope that it is better now, if not I am always at your disposal for further information on the problem I am facing.
