Sweep of face with hole: not working
manues
Re: Sweep of face with hole: not working
Post by manues »
thanks a lot for these last, most useful, inputs.
I have made a clean, commented version, which I share here. For me everything is fine now.
I just discovered an interesting swiping behavior, if going along non orthogonal intersections, where the profile cross-section starts to rotate out. But this has nothing to do with scripting I guess, but is just the general swiping behavior (not sure how this can be influenced). Below you will see the output of the provided code.
Thanks again.
import os
import FreeCAD
import FreeCADGui
from FreeCAD import Vector, Rotation, Placement
import Draft
import Sketcher
import Part
DOC = FreeCAD.newDocument()
#Create the body "Construction" containing the profiles  ******************
sweepBody = DOC.addObject("PartDesign::Body", "Construction")
#Define the path "wire_01", along which the sweep will be perfomed. ********
#Defind the path corners
p1 = Vector(0, 0, 0)
p2 = Vector(1000, 1000, 0)
p3 = Vector(2000, 0, 0)
p4 = Vector(2000, 1000, 1000)
p5= Vector(2000, 0, 1000)
p6= Vector(0,0, 500)
p7= Vector(1000,1000, 500)
#Construct the wire
wire_01 = Draft.make_wire([p1, p2, p3,p4,p5,p6,p7], closed=False)
#Add the wire to the scope of the body, by adding it to its group property
sweepBody.addObject(wire_01)
#Define sketch "xsection_01", which will be sweeped ********************
#Define the coners of an outer and innter rectangle, forming the profile face
# ... Outer rectangle corners
pp1 = Vector(-50, 50, 0)
pp2 = Vector(50, 50, 0)
pp3 = Vector(50, -50, 0)
pp4 = Vector(-50, -50, 0)
# ... Inner rectangle corners
ppp1 = Vector(-30, 30, 0)
ppp2 = Vector(30, 30, 0)
ppp3 = Vector(30, -30, 0)
ppp4 = Vector(-30, -30, 0)
#Define the sketch object
xsection_01 = sweepBody.newObject("Sketcher::SketchObject", "X-section_01")
#Add the line segments of hte outer rectangle
xsection_01.addGeometry(Part.LineSegment(pp1,pp2), False)
xsection_01.addGeometry(Part.LineSegment(pp2,pp3), False)
xsection_01.addGeometry(Part.LineSegment(pp3,pp4), False)
xsection_01.addGeometry(Part.LineSegment(pp4,pp1), False)
# ... connect its corner points
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 0,2,1,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 1,2,2,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 2,2,3,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 3,2,0,1))
#Add the line segments of hte inner rectangle
xsection_01.addGeometry(Part.LineSegment(ppp1,ppp2), False)
xsection_01.addGeometry(Part.LineSegment(ppp2,ppp3), False)
xsection_01.addGeometry(Part.LineSegment(ppp3,ppp4), False)
xsection_01.addGeometry(Part.LineSegment(ppp4,ppp1), False)
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 4,2,5,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 5,2,6,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 6,2,7,1))
xsection_01.addConstraint(Sketcher.Constraint("Coincident", 7,2,4,1))
# place and rotate the sketch to be at the beginning of wire_01 and normal to its first segment
xsection_01.Placement = Placement(Vector(0,0,0), Rotation(45, 90, 0))
xsection_01.recompute()
#Create the sweep Object, which is of "AdditivePipe" type
#Add sweep object to the containing Body "Construction"
sweepObject_01 = sweepBody.newObject("PartDesign::AdditivePipe", "Profile_01")
#Define the spine (path along which the swipe is performed)
sweepObject_01.Spine = wire_01
#Define the profile to be swiped
sweepObject_01.Profile = xsection_01
#Defines how the profile cross-section behaves in corners, options are:
#"Transformed": no turning of cross-section,
#"Right corner": cross-section remains in the sweep direction with sharp corners
#"Round corner": cross-section remains in the sweep direction with round corners
sweepObject_01.Transition = u"Right corner"
DOC.recompute()
The result is a follows:
Swipe along non orthogonal path
manues
Post by manues »
... when thinking about it, the rotation of the cross-section is probably a pure geometrical consequence. Otherwise the corners would not match.
