adrianinsaval wrote: ↑Fri Jun 30, 2023 11:09 pm
I tried adding the repo to the addon manager and installing but it doesn't work
The issue was related to
package.xml, that had no defined default branch (which should be set as
main), and
Addon Manager decides that default branch is
master (which was default on GitHub, for years).
- Screenshot_2023-07-09_17-49-35.png (140.88 KiB) Viewed 3219 times
So, Addon Manager tried to reach
master branch (ignoring even custom repo branch setting), then GitHub redirected it to
main and since then there is some issue with Addon Manager that does not fully detected this redirect, but still could install such addon. That is in part Addon Manager issue.
BTW, I just helped to fix this and
@MisterMaker already updated repo:
https://github.com/MisterMakerNL/Freeca ... /tree/main
Before install cleanup Addon Manager cache:
~/.cache/FreeCAD/Cache/AddonManager
Then restart FreeCAD, add custom repo into Addon Manager (do not forget set
main branch), launch Addon Manager and install theme.
- Screenshot_2023-07-09_20-16-39.png (69.44 KiB) Viewed 3204 times
