In the CfdOF panel where the "Point in Mesh" is set for snappyHexMesh, I had assumed that the boxes were in X,Y, Z order. However, when I look into the snappyHexMeshDict, it appears that X & Y is swapped. So if I enter, 10 mm, 20 mm, 30 mm into the CFD Mesh panel in CfdOF, in snappyHexMeshDict it will show up as:
locationInMesh (0.02 0.01 0.03);
What is going on here?
snappyHexMesh "Point in Mesh" Issue
Moderator: oliveroxtoby
Re: snappyHexMesh "Point in Mesh" Issue
Which release of FreeCAD are you using ? Is CfdOF updated to the newest version ? On my side, it works properly.
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
* CfdOF 1.22.6
* Help 1.0.3
- oliveroxtoby
Fixedmarkinca wrote: ↑Tue May 16, 2023 3:22 pm In the CfdOF panel where the "Point in Mesh" is set for snappyHexMesh, I had assumed that the boxes were in X,Y, Z order. However, when I look into the snappyHexMeshDict, it appears that X & Y is swapped. So if I enter, 10 mm, 20 mm, 30 mm into the CFD Mesh panel in CfdOF, in snappyHexMeshDict it will show up as:
