Multiple materials and Mesh
Moderator: bernd
lidiriel
Post by lidiriel »
Hi FEM users,
i try a simple example with two cylinders (see attachment freecad_cylinder screenshot)
center cylinder is in copper with potential of 1V and external cylinder is in glass. The external surface is at the potential of 0V.
Inspired by https://github.com/FreeCAD/FreeCAD/tree ... mexamples/ I have created :
  • booleanfragments (compSolid mode) with a compound filter (window-volume filter).
  • solid material copper associate to the internal cylinder
  • solid material glass to the external cylinder
but when i run elmer solver i have the error : ERROR:: ReadTargetNames: Mapping of name is not unique: solid2
if anybody have an idea of the problem ?
here the elmer log :
Executing solver...
ELMER SOLVER (v 9.0) STARTED AT: 2023/05/16 16:31:08
ParCommInit:  Initialize #PEs:            1
MAIN: OMP_NUM_THREADS not set. Using only 1 thread per task.
MAIN:
MAIN: =============================================================
MAIN: ElmerSolver finite element software, Welcome!
MAIN: This program is free software licensed under (L)GPL
MAIN: Copyright 1st April 1995 - , CSC - IT Center for Science Ltd.
MAIN: Webpage http://www.csc.fi/elmer, Email elmeradm@csc.fi
MAIN: Version: 9.0 (Rev: 40e221719, Compiled: 2023-05-05)
MAIN:  Running one task without MPI parallelization.
MAIN:  Running with just one thread per task.
MAIN:  MUMPS library linked in.
MAIN:  Lua interpreter linked in.
MAIN:
MAIN:
MAIN: -------------------------------------
MAIN: Reading Model: case.sif
LoadInputFile: Scanning input file: case.sif
LoadInputFile: Scanning only size info
LoadInputFile: First time visiting
LoadInputFile: Reading base load of sif file
LoadInputFile: Loading input file: case.sif
CheckKeyword:  Unlisted keyword: [potential constant] in section: [boundary condition 1]
LoadInputFile: Number of BCs: 2
LoadInputFile: Number of Body Forces: 0
LoadInputFile: Number of Initial Conditions: 0
LoadInputFile: Number of Materials: 1
LoadInputFile: Number of Equations: 2
LoadInputFile: Number of Solvers: 2
LoadInputFile: Number of Bodies: 2
ListTagKeywords: Setting weight for keywords!
ListTagKeywords: No parameters width suffix: normalize by area
ListTagKeywords: No parameters width suffix: normalize by volume
Loading user function library: [StatElecSolve]...[StatElecSolver_Init0]
Loading user function library: [ResultOutputSolve]...[ResultOutputSolver_Init0]
LoadMesh: Loading serial mesh!
ElmerAsciiMesh: Performing step: 1
ElmerAsciiMesh: Base mesh name: .
ReadHeaderFile: Reading header info from file: ./mesh.header
InitializeMesh: Number of nodes in mesh: 24342
InitializeMesh: Number of bulk elements in mesh: 15948
InitializeMesh: Number of boundary elements in mesh: 4268
InitializeMesh: Initial number of max element nodes: 10
ElmerAsciiMesh: Performing step: 2
ReadNodesFile: Reading nodes from file: ./mesh.nodes
MapCoordinates: Performing coordinate mapping
SetMeshDimension: Dimension of mesh is: 3
SetMeshDimension: Max dimension of mesh is: 3
MapCoordinates: Scaling coordinates: 1.000E-03 1.000E-03 1.000E-03
ElmerAsciiMesh: Performing step: 3
ReadElementsFile: Reading bulk elements from file: ./mesh.elements
ElmerAsciiMesh: Performing step: 4
ReadBoundaryFile: Reading boundary elements from file: ./mesh.boundary
PermuteNodeNumbering: Performing node mapping
ReadTargetNames: Reading names info from file: ./mesh.names
No result file was created.
my case.sif :
Check Keywords "Warn"
Header
  Mesh DB "."
End
Solver 1
  Calculate Electric Energy = Logical True
  Calculate Electric Field = Logical True
  Equation = String "Stat Elec Solver"
  Exec Solver = String "Always"
  Linear System Abort Not Converged = Logical False
  Linear System Convergence Tolerance = Real 1e-10
  Linear System Iterative Method = String "BiCGStab"
  Linear System Max Iterations = Integer 500
  Linear System Precondition Recompute = Integer 1
  Linear System Preconditioning = String "ILU0"
  Linear System Residual Output = Integer 1
  Linear System Solver = String "Iterative"
  Optimize Bandwidth = Logical True
  Procedure = File "StatElecSolve" "StatElecSolver"
  Stabilize = Logical True
  Steady State Convergence Tolerance = Real 1e-05
  Variable = String "Potential"
  Variable DOFs = Integer 1
End
Simulation
  Coordinate Mapping(3) = Integer 1 2 3
  Coordinate Scaling = Real 0.001
  Coordinate System = String "Cartesian 3D"
  Output Intervals = Integer 1
  Simulation Type = String "Steady State"
  Steady State Max Iterations = Integer 1
  Steady State Min Iterations = Integer 0
  Use Mesh Names = Logical True
End
Constants
  Permittivity Of Vacuum = Real 8.854189999999999e-12
End
Body 1
  Equation = Integer 1
  Material = Integer 1
  Name = String "Solid1"
End
Material 1
  Relative Permittivity = Real 5.0
End
Equation 1
  Active Solvers(2) = Integer 1 2
End
Solver 2
  Coordinate Scaling Revert = Logical True
  Equation = String "ResultOutput"
  Exec Solver = String "After simulation"
  Output File Name = File "case"
  Procedure = File "ResultOutputSolve" "ResultOutputSolver"
  Vtu Format = Logical True
End
Body 2
  Equation = Integer 2
  Name = String "Solid2"
End
Equation 2
End
Boundary Condition 1
  Potential = Real 1.0
  Potential Constant = Logical True
End
Boundary Condition 2
  Name = String "Face1"
  Potential = Real 0.0
End
mesh.names
! ----- names for bodies -----
$ Solid1 = 3
$ Solid2 = 4
! ----- names for boundaries -----
$ Face1 = 2
$ bnry5 = 5
$ bnry6 = 6
entities.sif
!------ Skeleton for body section -----
Body 1
  Name = Solid1
End
Body 2
  Name = Solid2
End
!------ Skeleton for boundary section -----
  Name = Face1
End
  Name = bnry5
End
Boundary Condition 3
  Name = bnry6
End
My configuration is :
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.2.29603 (Git) AppImage
Locale: French/France (fr_FR)
  * fasteners 0.4.52
  * ThreadProfile 1.84.0
RichB2k
Re: Multiple materials and Mesh
Post by RichB2k »
Take a look at this Elmer forum post, it may help.
http://www.elmerfem.org/forum/viewtopic.php?t=7968
Thanks, Rich.
lidiriel
Post by lidiriel »
i have read this thread :
RichB2k wrote: Tue May 16, 2023 4:58 pm Take a look at this Elmer forum post, it may help.
but i have no idea to resolv my problem.
in the file shape2mesh.geo
// save
Mesh.Format = 2;
// Ignore Physical definitions and save all elements;
Mesh.SaveAll = 1;
Save "/home/ludovic/Elmer/test/cylinder2/FEMMeshGmsh/CompoundFilter_Mesh.unv";
the option SaveAll is set to 1. But i don't know how i can change this option to test.
RichB2k
Post by RichB2k »
Looks like the automated build process that calls gmsh isn't working well for you.
In this post:
viewtopic.php?t=77149&sid=91a6d7a8655c6 ... 2c13844766
To test the new features, I created a Windows build:
https://github.com/FreeCAD/FreeCAD-Bund ... taller.exe
for Linux and MacOS, wait for the next weekly build:
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
(must have revision number 32552 or higher)
Where in your first post, this is the version number:
If you update your version of FreeCAD, does it help?
Also, if you could post your FreeCAD example file, that would help.
Thanks, Rich.
lidiriel
Post by lidiriel »
I use
  • freecad 0.20.2 git revision 29603
  • gmsh 4.11.1
  • elmer local compilation from devel branch (commit 40e2217199a2fb69a48cb3c04a1ad841ea784579)
i will try to upgrade freecad.
here you can download the test file cylinder2.FCStd and generated files by gmsh and Elmer : https://filesender.renater.fr/?s=downlo ... 33519076a2
regards
lidiriel
Post by lidiriel »
with the last freecad version :
Version: 0.21.0.33263 (Git) AppImage
Hash: 864f99bf984c237ef38d9451fd6f3a5ec34e6eb4
i can't load the FEM workbench
11:10:30  /tmp/.mount_FreeCABa46ej/usr/lib/././libnglib4smesh.so: undefined symbol: _ZNK17XCAFDoc_ColorTool8GetColorERK9TDF_LabelR14Quantity_Color
11:10:30  Traceback (most recent call last):
  File "<string>", line 71, in Initialize
  File "/tmp/.mount_FreeCABa46ej/usr/lib/python3.11/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
It is linked to the issue : https://github.com/FreeCAD/FreeCAD-Bundle/issues/173
RichB2k
Post by RichB2k »
Loading and running your file cylinder2.FCStd, I get the same error message from elmersolver.
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
The release date is listed as 2023/03/26
The errors seem to be related to naming of bodies and surfaces. I don't know enough about FreeCAD to be helpful, but at least you can stay with your old version and maybe figure out a different approach to naming the parts.
Rich.
AlbertoR
Post by AlbertoR »
I got exactly the same problem in another model, I can provide it if it is necessary.
From my investigation it is related to the constraint: changing it the computation can go on.
I tried to make some work around defining the references of the constraints using the Python console* without success.
* the python instruction is:
FreeCAD.getDocument('<filename>').getObject('ConstraintElectrostaticPotential002').References = (FreeCAD.getDocument('<filename>').getObject('BooleanFragments'),u'Solid1')
I have also named the reference with 'SOlid1' but in the ELMER log it is reported always as 'solid1' and thus it seems that string is somehow translated in a only-lowercase word.
Anyway if you use the Faces instead of the Solids to reference the constraints the problem could disappear (at least it disappeared to me).
Regards,
Alberto
