thanks, it is working. if I only make the two parts into one compound, the colors remain. will from now on create a compound after each mirroring. if this creates new problems, I'll report back here
(WORKAROUND) User error when mirroring and rotating?
- thomas-neemann
Re: User error when mirroring and rotating?
Re: (WORKAROUND) User error when mirroring and rotating?
An additional solution would be to create a clone of the original object, and hide the original object. Then rotate the clone, not the original object
- thomas-neemann
thanks, i will test it
