Appimage update fails
drmacro
Re: Appimage update fails
Post by drmacro »
adrianinsaval wrote: Sun May 21, 2023 10:00 pm an appimage should be available shortly (around 15min): https://github.com/FreeCAD/FreeCAD-Bundle/pull/175
Thanks!
Just to confirm, did the appimage update and it worked.
intufreecad
Post by intufreecad »
Yes updated appimage today everything fine.
OS: Linux 6.3.2-arch1-1 (XFCE/openbox)
Version: 0.21.0.33263 (Git) AppImage
Hash: 864f99bf984c237ef38d9451fd6f3a5ec34e6eb4
Python 3.11.3, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.2, OCC 7.7.1
  * Silk 0.1.3
  * Assembly4 0.50.1
  * nurbs
  * BIM 2021.12.0
  * lattice2 1.0.0
  * CurvedShapes 1.0.4
  * Nodes 0.1.36
  * Curves 0.6.8
  * sheetmetal 0.2.63
  * POV-Ray-Rendering
  * Manipulator 1.5.0
  * QuickMeasure 2022.10.28
  * dodo 1.0.0
  * Pyramids-and-Polyhedrons
Marcel a freecad lover
Laurie Hartley
Post by Laurie Hartley »
I ran the update routine via the check for new version interface. It found the new appimage however when I try to run it the splash screen appear, I see it loading the workbenches then it disappears. In other words it doesn't completely load.
I then tried downloading it from github into my downloads folder but the same thin happened - splash screen but then no GUI.
My existing version is working fine.
I am on MX Linux a Debian based OS. ??? Attached is a screenshot showing the download version detail
Laurie Hartley
Laurie Hartley wrote: Wed May 24, 2023 7:45 am I then tried downloading it from github into my downloads folder but the same thin happened - splash screen but then no GUI.
I have just remembered I had a similar problem a couple of years ago. I wonder if this is in some way related to the “ opengl32sw.dll and rename it opengl32.dll” comment in this thread?
viewtopic.php?p=531321#p531321
Run the appimage film terminal and copy paste here what error message is displayed
Laurie Hartley
adrianinsaval wrote: Wed May 24, 2023 1:37 pm Run the appimage film terminal and copy paste here what error message is displayed
Thanks for your help adrianinsaval. Here is the output from the terminal:-
Also below that is my system graphics info.
Laurie@ThinkPadE595:~/opt/FreeCAD Weekly Builds
$ ls
 FreeCAD.AppImage                                                          'Last Week'
 FreeCAD_weekly-builds-33263-2023-05-21-conda-Linux-x86_64-py311.AppImage
$ FreeCAD_weekly-builds-33263-2023-05-21-conda-Linux-x86_64-py311.AppImage
bash: FreeCAD_weekly-builds-33263-2023-05-21-conda-Linux-x86_64-py311.AppImage: command not found
$ ./FreeCAD_weekly-builds-33263-2023-05-21-conda-Linux-x86_64-py311.AppImage
FreeCAD 0.21.0, Libs: 0.21.0R33263 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2023
Sheet Metal workbench loaded
/home/runner/work/FreeCAD-Bundle/FreeCAD-Bundle/conda/linux/AppDir/usr/share/libdrm/amdgpu.ids: No such file or directory
('Mod/Pyramids_and_polyhedrons', 'Mod/Pyramids-and-Polyhedrons', 'Mod/FreeCAD-Pyramids-and-Polyhedrons', 'Mod/Pyramids-and-polyhedrons')
flag
flag2
During initialization the error "/tmp/.mount_FreeCAt6O6vX/usr/lib/././libnglib4smesh.so: undefined symbol: _ZNK17XCAFDoc_ColorTool8GetColorERK9TDF_LabelR14Quantity_Color" occurred in /home/Laurie/.local/share/FreeCAD/Mod/Cfd/InitGui.py
Please look into the log file for further information
/tmp/.mount_FreeCAt6O6vX/AppRun: line 43: 10909 Trace/breakpoint trap   ${MAIN} "$@"
SYSTEM GRAPHICS INFO
Graphics:  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
           vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel bus-ID: 05:00.0
           chip-ID: 1002:15d8 class-ID: 0300
           Device-2: IMC Networks type: USB driver: uvcvideo bus-ID: 3-2:3 chip-ID: 13d3:5415
           class-ID: 0e02
           Display: x11 server: X.Org 1.20.10 compositor: xfwm4 v: 4.14.0 driver: loaded: amdgpu
           display-ID: :0.0 screens: 1
           Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
           s-diag: 1055mm (41.5")
           Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
           diag: 395mm (15.5")
           Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
           diag: 1836mm (72.3")
           OpenGL:
           renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.42.0 5.14.0-3mx-amd64 LLVM 11.0.1)
           v: 4.6 Mesa 20.3.5 direct render: Yes
xemul
Post by xemul »
You could:
- `touch ~/.freecad/Mod/FreeCAD-Pyramids-and-Polyhedrons/ADDON_DISABLED`;
or
- `cp ~/.freecad/user.cfg ~/.freecad/user_wo_PnP.cfg`, remove from ~/.freecad/user_wo_PnP.cfg Pyramids-and-Polyhedrons section
you'll need to start FC by "FreeCAD_weekly-builds-33263-2023-05-21-conda-Linux-x86_64-py311.AppImage -u ~/.freecad/user_wo_PnP.cfg";
or
- find libnglib4smesh.so in some previous FreeCAD build, unpack .Appimage and copy libnglib4smesh.so to <path_to_unpacked_FC>/usr/lib/
you'll need to start FC by <path_to_unpacked_FC>/AppRun .
xemul wrote: Thu May 25, 2023 11:52 am - find libnglib4smesh.so in some previous FreeCAD build, unpack .Appimage and copy libnglib4smesh.so to <path_to_unpacked_FC>/usr/lib/
I don't think that will work, the problem is that we are still using the same smesh as before but upgraded occt, smesh needs to be rebuilt with the new occt
Laurie Hartley
@xemul and @adrianinsaval - Thank you both - maybe at this stage perhaps I should settle for what I have got in the form of the April appimage as I am presuming this problem may be solved sometime in the not too distant future.
Try the latest appimage, I reverted back to older libraries as workaround while we wait for smesh to be fixed
